Red Bull RB16B
jjn9128
785
Re: Red Bull RB16B
Stu wrote:
26 Sep 2021, 13:19
Sevach wrote:
25 Sep 2021, 23:50
Predictably, Max took out some rear wing.
https://cdn-1.motorsport.com/images/mgl ... ing-1.webp
Bodes well if dry, everyone on the grid went barn door.
I wonder when the other teams noticed, MV only completed an out lap….
Sure did but it's fine
https://www.fia.com/sites/default/files ... n%20Q1.pdf
#aerogandalf
Stu
Re: Red Bull RB16B
jjn9128 wrote:
26 Sep 2021, 13:20
Stu wrote:
26 Sep 2021, 13:19
Sevach wrote:
25 Sep 2021, 23:50
That is good news! But tbh, I was wondering what they thought when they clocked his aero set-up?
ispano6
164
Re: Red Bull RB16B
Stu wrote:
26 Sep 2021, 13:19
Sevach wrote:
25 Sep 2021, 23:50
The team expected rain and just had to make sure Max could drive with intermediates with that set up, which he confirmed after quali that the car had good grip with the inters. Those last few laps on slicks were masterclass.
NathanOlder
Re: Red Bull RB16B
ispano6 wrote:
27 Sep 2021, 21:00
Stu wrote:
26 Sep 2021, 13:19
Sevach wrote:
25 Sep 2021, 23:50
Yeah the guys on the softer compounds stood out for those few laps. I. couldn't believe it when we saw Giovinazzi overtaking Lando when they were trying to tip toe around.
GoLandoGo
Lewis v2.0
King George has arrived.
Re: Red Bull RB16B
Via AMuS
Via Motorsport.com
Stu
Re: Red Bull RB16B
That is some groovy --- going on at the leading edge of the floor! Looks like a mini-version of 2022…..
Bandit1216
21
Re: Red Bull RB16B
No spring at all???
I also wonder whether some wishbones these days are one piece from right to left. Carbon-comp being bendy enough to discard a actual pivot point al together.
But just suppose it weren't hypothetical.
henry
324
Re: Red Bull RB16B
Bandit1216 wrote:
08 Oct 2021, 09:13
No spring at all???
Might the discs on the right be a stack of Belleville washers? Or a bellows that contains hydraulic fluid that’s pumped elsewhere.
There also seems to be a lack of an inerter. Maybe they’re experimenting for next year?
Bandit1216
21
Re: Red Bull RB16B
henry wrote:
08 Oct 2021, 10:16
Bandit1216 wrote:
08 Oct 2021, 09:13
No spring at all???
I really wonder. Might be the actual spring is in the bottom where the ARB is, and this is only a guide with sensor. It looks like bellevilles indeed, but that would mean a travel of a few mm. The black/green turn thingy near the presumed bellevilles looks like a ride height adjuster to me.
zibby43
zibby43
Re: Red Bull RB16B
Re: Red Bull RB16B
Bandit1216 wrote:
08 Oct 2021, 09:13
No spring at all???
They use torsion bar springs for the individual wheel springs. These run through the pivot point of the bell crank. This device is the third spring (heave spring).
henry
324
Re: Red Bull RB16B
Just_a_fan wrote:
09 Oct 2021, 09:30
Bandit1216 wrote:
08 Oct 2021, 09:13
No spring at all???
The device between the two rockers is usually a combined spring and inerter. The previous version was much bigger diameter. It’s difficult to see how this new device performs both functions in the way the previous one did given its reduced size.
Next year inerters are banned.
jh199
32
Re: Red Bull RB16B
Good video showing the Y250 vortex off the front wing
Edit: Adding u/Cistoran for credit from Reddit.
continuum16
52
Re: Red Bull RB16B
Maybe not anything new but cool to see the flow around the sidepods a bit.
- Mark Twain
Re: Red Bull RB16B
continuum16 wrote:
12 Oct 2021, 16:34
Interesting that the two cars have slightly different "flow viz" marks around the sidepods. I wonder if that is due to something such as slightly different front wing settings. (right click to open hi-res image)
