2021 AMG Mercedes F1 Team
dans79
267
Re: 2021 AMG Mercedes F1 Team
214270 wrote:
22 Oct 2021, 19:54
If they’re testing, don’t they need to declare the specifics to justify a change on reliability grounds though? ie. RB would know and announce with glee to the world Merc’s engine troubles.
Not if they are messing with mappings, boost etc.
The other teams don't get told anything unless you are physically modified a component. Even then the details other teams get are vague and generalized.
197 104 103 7
16
dans79 wrote:
22 Oct 2021, 20:01
214270 wrote:
22 Oct 2021, 19:54
Wouldn’t that be done on a dyno? In this way done live on track surely if they were actually testing, you’d test ‘new’ elements?
dans79
267
214270 wrote:
22 Oct 2021, 20:16
dans79 wrote:
22 Oct 2021, 20:01
214270 wrote:
22 Oct 2021, 19:54
you won't get real world g loads, air flow, cooling etc. on a test bench.
197 104 103 7
16
dans79 wrote:
22 Oct 2021, 20:21
214270 wrote:
22 Oct 2021, 20:16
dans79 wrote:
22 Oct 2021, 20:01
Fair enough 👍
zibby43
613
Huge news, if true.
Thanks for finding this, b2bL.
darkpino
I thought that once you go over your engine allocation (so when using fourth, fifth and sixth engine) you can only use the sixth. But conversation with my friends caught me a bit unsure about this. Can anyone shine some light on this?
Gillian
darkpino wrote:
22 Oct 2021, 21:41
That rule is about stacking PU in a single weekend. So if a driver gets 2 new PU in a weekend, only the PU used in the race will be added to the pool.
In this case it's a new weekend and a new PU so this new PU will be added to the pool and the oldest will be removed.
darkpino
So basically Bottas has 3 new PU’s right now? Nice…
darkpino wrote:
22 Oct 2021, 21:45
doesnt really matter though, he just opens the door for Max anyway,
all that's missing is putting his arm out and making a bow.
Essentially, it's Hamilton vs the RedBull Army consisting of Max, Bottas, Perez, Gasly and Tsunoda. Next season that includes Albon.
AeroDynamic
349
Armchair experts are going to love reading this article.
https://the-race.com/formula-1/gary-and ... ion-trick/
This device was always present but it wasn't able to be used until recently. Remeber the issues they had with floor stability? Yeah., was porbably too risky to have that drop activate back then.
search
darkpino wrote:
22 Oct 2021, 21:45
no, there were problems wih the one introduced in Monza, and it's not usable anymore
Gillian
Manoah2u wrote:
23 Oct 2021, 00:52
darkpino wrote:
22 Oct 2021, 21:45
But it does matter as you could see in Turkey. Its not like Bottas will pull over to let Verstappen by if he has more pace. Maybe that's a reason to give Bottas another fresh PU. It could be Mercedes thinks it will give enough performance to keep Bottas in front of Verstappen.
Hammerfist
If bottas can get to the top 4 rather efficiently he should be in verstappens pit window before the first stops. But that is a big if and realistically he will struggle to get by the Mclarens and Ferraris.
InsaneX_Badger
Hammerfist wrote:
24 Oct 2021, 10:11
Let's hope that they have pushed the set up to be more responsive in dirty air.
