Starkblood80 wrote: ↑14 Nov 2021, 12:30
Stu wrote: ↑14 Nov 2021, 12:07
NathanOlder wrote: ↑14 Nov 2021, 10:09
I'm guessing they check these things as regularly as other teams. If the 0.2 mm is correct, then clearly this is something that could have happened during that very session. 0.2mm is nothing!! the average human hair is 0.075mm so this 0.2mm is LESS than 3 hairs!
And it was 94 not 95.
Thanks for the correction on the year for the Schumacher DQ. My point with the checking of the part for wear, is that there would be a known amount of wear that will take place with activation, this is how you would life a part such as this (especially with the regulation having a ‘hard maximum’ for the allowed dimension); don’t forget, due to parc ferme applying from the start of qualifying, this rear wing would then go on to complete qualifying, FP2, sprint race & GP and still must remain within the ‘hard maximum’. Plainly, in this instance, their internal processes have failed!
OR…
The FIA/scrutineers infrequently check this dimension and Mercedes have now had their own grey-area discovered.
TBF, this could have been going on for ages (years?), and the ‘flexi-wing saga’ from earlier this year was just a political game.
Who knows??
If, as it seems, Red Bull highlighted this to scrutineers once qualifying had commenced(???), they are being reasonably fair-minded toward their championship rival (in that Mercedes have now had the opportunity to replace an out of regulation part). I would have waited until the GP started & going for the full race DQ for maximum competitive advantage!!
I doubt Redbull would have noticed a 0.2mm difference on only one side of the DRS from tv footage but Mercedes didn’t. Not only that but I think RB went to the FIA about wing flex rather than the DRS slot gap.
For several years they have been estimating engine power from sound.
The FIA have now given them ALL reference points on the rear wing, along with live coverage on the rear view. Indeed the FIA themselves are supposedly using these for enforcement. If a team thinks that something untoward is occurring, they will have people who are monitoring (and probably using very precise software for it too).
This will be how Mercedes latched into the Red Bull wing flex (even though it passed the test), there is a certain irony to Mercedes being caught by the same rule.
Their DRS slot measured 0.2mm above the ‘hard maximum’ after qualifying, where would it be after the rest of the weekend? If that is caused by wear (that Red Bull may not be able to measure), how much flex in that element are they seeing at speed?
Don’t forget, if the rules state a ‘hard maximum’, it likely pays to utilise it.
