Aston Martin AMR22 Speculation Thread
wogx
wogx
22
Stu
Re: Aston Martin AMR22 Speculation Thread
With them *ahem* ‘borrowing’ the last Racing Point car from Mercedes, and then adapting it to 2021 modifications, it could be argued that they could have a huge head start on all of the other teams this year!
Common sense is not as common as stupidity, but it is better to be uninformed than to be mis-informed...
AeroDynamic
Stu wrote:
Fri Jan 14, 2022 1:26 pm
Possibly. Do we think Andrew Green is lying when he suggests it’s a lot more difficult than it sounds, as well as saying it takes a lot to figure out the concept and develop it to work?
’cause
When we rhyme–we shine,
showing no weak signs
Each time you peep,
rewind these deep lines
I know I’m,
in a zone of my own kind
so I just get down,
and I go for mines.
El Scorchio
You could argue the same for Haas as well, with their total lack of 2021 development, and some other teams. I guess all teams had the same decision- develop through 2021 or don't bother, and put more time and resource into 2022.
Is it any more than what RBR/AT and Ferrari/AR can achieve by splitting development across two teams? You could also argue that's a huge head start.
NAPI10
NAPI10
I think, they will go back to Force India philosophy.
Start the season with a base version that can be molded/change in any technical direction. Then keep introducing new versions as the season progress by observing innovations by other teams.
El Scorchio
NAPI10 wrote:
Fri Jan 14, 2022 5:01 pm
I think a lot of teams will do this. Start with a fairly 'neutral' and all round design rather than going too far down a path that might be hard to come back from.
NAPI10
NAPI10
El Scorchio wrote:
Fri Jan 14, 2022 5:08 pm
True to that but it also brings opportunity for the midfield team just like 'Brawn' in 2009.
El Scorchio
NAPI10 wrote:
Fri Jan 14, 2022 6:14 pm
Absolutely agree. I reckon the Haas and Williams teams etc. are in a nothing to lose scenario- everyone expects them to be dead last so they might as well go for broke with something radical. If it pays off and they find a magic solution they could have an amazing season, and if it doesn't, they just start from scratch next season, looking at what worked this season. I reckon AT and AR will go down that daring route as well to help their sister teams gather information and test philosophies.
However, to bring it back on topic and to Aston, :wink: I believe they, with the other bigger 4-5 teams will play it pretty safe and risk averse at first so as not to be at a serious disadvantage, then quickly learn from testing and the first few races what they need to do in relation to their competitors and really start chucking on big updates if needed. A big mis-step now could cost a few years to put right.
I could of course be totally wrong, but that's the fun in all this isn't it!
NAPI10
NAPI10
El Scorchio wrote:
Fri Jan 14, 2022 7:07 pm
Plus their big appointments joining the team later half of 22 or in 23. These guys will have a lot of inputs.
Looking at that, team won't commit to certain design philosophy; at least in the first half of the season.
El Scorchio
NAPI10 wrote:
Fri Jan 14, 2022 8:01 pm
True. I agree it's an indication that Stroll sr really means business. And the man clearly knows how to run a business!
Big Tea
76
oops, sorry should be in the other thread (and it is) so deleted
I saw two shooting stars last night, I wished on them but they were only satellites. Its wrong to wish on space hardware I wish, I wish...
TimmTurbo
TimmTurbo
Do you guys really think that the teams choose between a radical or mild approach?
I don’t think so. At the end of the day it all comes down to the most promising numbers and figures. They probably spent a tremendous amount of work into verifying their measurements. After that or in parallel they investigated into directions which simply promised to perform better over the other option. I don’t think any Lead in Engineering is interested in keeping things „easy“ for the sake of not making any mistakes or being too radical. It all boils down to pure lap time.
At least what I would expect all of them to do
Big Tea
76
TimmTurbo wrote:
Sat Jan 15, 2022 9:59 pm
I would assume there are some areas where they consider some things slightly 'throttled back' thinking they cam probably go a little more radical later in the season.
They want a fast car, but they also want a stable car and a car they understand. I would be leaning somewhat to the conservative side of anything 'too cutting edge', but not forgetting about it, just not gambling too hard on it.
But, then again, I am not a F1 engineer and giant steps may be what you take.
