McLaren MCL36 Speculation Thread
billamend
billamend
Re: McLaren MCL36 Speculation Thread
Stu wrote:
27 Jan 2022, 18:08
If the image that appears to show pull-rod front suspension is a view of the front of the tub from the rear it has a very unusual shape.
I was thinking the same. I can't _really_ figure out what is going on, but it does seem like an odd shape.
Mattchu
60
Mostlyeels wrote:
27 Jan 2022, 20:13
It's been a while since I looked closely at a steering wheel. What are the 2 rows of 3 LEDs on each side of the display used for?
Pretty sure they`re the FIA flag/marshall lights, a blue one, a red one and a yellow one to correspond to the flag that is being waved...
Mostlyeels
Mostlyeels
Mattchu wrote:
27 Jan 2022, 22:50
Mostlyeels wrote:
27 Jan 2022, 20:13
Thanks. I'll have to keep a closer eye on them the next time.
wogx
60
bauc wrote:
27 Jan 2022, 17:05
No DRS button?
BlueCheetah66
BlueCheetah66
33
wogx wrote:
27 Jan 2022, 23:28
bauc wrote:
27 Jan 2022, 17:05
No DRS button?
I'm think most teams now have it turn on automatically when its available
lucafo
haza wrote:
27 Jan 2022, 19:16
I spotted this in the fire up yesterday
Yes! The sidepod looks very different!
It looks that the safety impact structure is placed higher again but it is located back the entry of the cooling.
It means that the lateral cooling maybe is placed in a far forward position; and also the radiators!
wogx
60
An older car side pod for comparision:
So it could look like that? What do you think?
michl420
michl420
BlueCheetah66 wrote:
27 Jan 2022, 23:38
wogx wrote:
27 Jan 2022, 23:28
bauc wrote:
27 Jan 2022, 17:05
No DRS button?
Activate it automatically is pretty sure forbbiden (safety reason). It is likely on the rear side as a paddle.
michl420
michl420
billamend wrote:
27 Jan 2022, 20:20
Stu wrote:
27 Jan 2022, 18:08
2 things look unusual in this image.
1. This pull-rod has a step agle. Maybe the tub is that low or it is mounted in the tea tray area.
2. It looks like the nose/monocoque fall down very early, beause I not can see it.
(Or it's an optical illusion and I'm wrong)
Ground Effect
Ground Effect
Good article on McLaren’s focus on improving low-speed performance. James Key, gives good insight, as usual.
https://www.motorsport.com/f1/news/mcla ... r/7647234/
lucafo
Perfect!
If I had to put some money that would be my choice.
Thanks!
McFAN
McFAN
Technical Insight: Pull rod suspension confirmed on McLaren MCL36
https://www.motorsportweek.com/2022/01/ ... aren-mcl36/
Ground Effect
Ground Effect
More talk about Mclaren’s alleged switch to the pull-rod suspension.
https://www.motorsport.com/f1/news/the- ... o/7765674/
mythr-ran-dire
mythr-ran-dire
AMuS is claiming Mclaren might show up in Barcelona with a basic spec as opposed to the fully realized 2022 car. Interesting approach if true.
Source: https://www.auto-motor-und-sport.de/for ... udget-cap/
]=Do=>}
~~ ]=Do=>}
Wheel-to-wheel
SmallSoldier
SmallSoldier
486
mythr-ran-dire wrote:
31 Jan 2022, 22:43
Seems that they wanted to make an article on the 2 potential approaches (Basic car in Barcelona and Developed car in Bahrain or Developed Car in Barcelona) and simply used McLaren as an example of it…
Whether they can bring a basic car and then a developed one is a matter of cost… I understand the reluctancy of Teams to bring their cars to Barcelona and let the other Teams copy their solutions, but correlation tests in Barcelona could be crucial… If a team gets 3 complete days of testing on their “close to racing spec” car it could also be a major advantage going into the season.
