McLaren MCL36
Mchamilton
Mchamilton
Re: McLaren MCL36
SmallSoldier wrote:
20 Feb 2022, 03:39
It’s striking how far forward the new sidepod inlets are compared to the MCL35M (and previous cars), you can tell comparing with the base of the halo, with how much forward the sidepods are, you have to assume that radiators and other ancillaries have been moved towards the new space created with the forward sidepods, which should have had an impact not only on the volume required at the back (making it slimmer), but also moving the COG forward more towards the center of the car… It also shows how much space has been gained from moving from Pull Rod to Push Rod in the rear based on the position of the rod itself in the previous cars:
https://i.imgur.com/67QmU81.jpg
All teams have had to move their COG forward because the centre of pressure from the floor is now much further forward. Also to simply accomodate the high tunnels.
Stu
Re: McLaren MCL36
Mchamilton wrote:
20 Feb 2022, 10:50
SmallSoldier wrote:
20 Feb 2022, 03:39
Weight distribution is still tightly controlled within the regulations (although there is a slight change in what is permissible).
Edit: Cut & paste from regulations.
4.2 Mass distribution
With the car resting on a horizontal plane the mass measured at the front and rear axles must not be less than the mass specified in Article 4.1 factored by 0.440 and 0.540 respectively at all times during the qualifying practice session. Rounding will be to nearest 0.5kg.
If, when required for checking, a car is not already fitted with dry-weather tyres, its mass will be determined using a set of dry-weather tyres selected by the FIA technical delegate.
Re: McLaren MCL36
Stu wrote:
20 Feb 2022, 11:26
Mchamilton wrote:
20 Feb 2022, 10:50
SmallSoldier wrote:
20 Feb 2022, 03:39
Weight distribution is still controlled within the regulations (although there is a slight change in what is permissible).
And it's more rearward than 2021... :-k
Tim.Wright
330
Re: McLaren MCL36
SmallSoldier wrote:
20 Feb 2022, 10:29
I’m sure the team is taken that into consideration and trying to bring the best possible balance… I don’t think that moving COG forward would hamper the car’s acceleration, that’s more related to weight transfer and mechanical grip than where the weight resides passively
Unless you are lifting the front wheels off the ground during a launch, there is always an advantage to moving the CG rearwards on a RWD car.
Wheel load = static weight load + load transfer.
Load transfer is relatively small given the low CG height and long wheelbase.
CjC
CjC
Re: McLaren MCL36
SmallSoldier wrote:
20 Feb 2022, 10:29
CjC wrote:
20 Feb 2022, 10:23
SmallSoldier wrote:
20 Feb 2022, 03:39
Interesting.
If your theory is correct moving the COG forward could harm the exceptional launches Mclaren sort of became renowned for last season and also the good traction characteristic.
However it could improve front rotation for the slow corners which have been an Achilles heel for Mclaren over the last few seasons?
Then again the fact that they have swapped the pull/push rods front and back will alter any advantage or disadvantage they used have.
Think I’m just going to forget any characteristics from the previous seasons and just wait till mid season before making any more
Just a fan's point of view
the EDGE
the EDGE
68
Re: McLaren MCL36
Mchamilton wrote:
20 Feb 2022, 10:50
SmallSoldier wrote:
20 Feb 2022, 03:39
The only reason they were ever that far back was to make room for the barge boards following the front wing simplification change a few years ago
nevill3
16
Re: McLaren MCL36
Stu wrote:
20 Feb 2022, 11:26
Mchamilton wrote:
20 Feb 2022, 10:50
SmallSoldier wrote:
20 Feb 2022, 03:39
That cut and past is slightly wrong this years updated regulations have an increase to the front but not the rear weight distribution
ARTICLE 4: MASS
4.1 Minimum mass
The mass of the car, without fuel, must not be less than 775Kg 790Kg at all times during the
Competition.
not be less than the mass specified in Article 4.1 factored by 0.440 0.445 and 0.540
respectively
0.5kg.
Mchamilton
Mchamilton
Re: McLaren MCL36
Blackout wrote:
20 Feb 2022, 11:29
Stu wrote:
20 Feb 2022, 11:26
Mchamilton wrote:
20 Feb 2022, 10:50
So it is, 5% further rearward, suprised by that tbh
Fer.Fan
Fer.Fan
Re: McLaren MCL36
Mchamilton wrote:
20 Feb 2022, 10:50
SmallSoldier wrote:
20 Feb 2022, 03:39
Not all teams have moved their COG forward. Just look att new W13, compare how far back their sidepods sits compared to mcl36 or ferrari. It is strange…
SmallSoldier
SmallSoldier
486
Re: McLaren MCL36
Tim.Wright wrote:
20 Feb 2022, 11:32
SmallSoldier wrote:
20 Feb 2022, 10:29
Thank you, but even if you aren’t lifting the tires from the ground, wouldn’t the rear biased CG induce understeer?
I thought weight transfer (and therefore suspension setup) had a bigger influence, but I’m sure I’m wrong
SmallSoldier
SmallSoldier
486
Re: McLaren MCL36
Fer.Fan wrote:
20 Feb 2022, 14:57
Mchamilton wrote:
20 Feb 2022, 10:50
SmallSoldier wrote:
20 Feb 2022, 03:39
They seem to be forward in the actual car, the render is the one that has them back (as per previous cars)
SmallSoldier
SmallSoldier
486
Re: McLaren MCL36
CjC wrote:
20 Feb 2022, 11:40
SmallSoldier wrote:
20 Feb 2022, 10:29
CjC wrote:
20 Feb 2022, 10:23
Interesting.
I’m taking the same advice… It’s fun to speculate, but it’s better to actually see them on track
Tim.Wright
330
Re: McLaren MCL36
SmallSoldier wrote:
20 Feb 2022, 19:09
Load transfer accounts for only around 10-15% of the load of the rear (driven) wheels. Most of the load is from the static weight load.
Shifting weight rearwards will typically induce a reduction in transient stability and a loss of understeer.
SmallSoldier
SmallSoldier
486
Re: McLaren MCL36
Tim.Wright wrote:
20 Feb 2022, 19:33
SmallSoldier wrote:
20 Feb 2022, 19:09
Could you elaborate a bit more please? Trying to figure it out since in my mind it always worked the other way, wouldn’t transferring weight rearwards induce understeer by making the front lighter (therefore reducing grip)… Trying to understand/learn the concept.
Thanks!
Stu
Re: McLaren MCL36
SmallSoldier wrote:
20 Feb 2022, 19:53
Tim.Wright wrote:
20 Feb 2022, 19:33
SmallSoldier wrote:
20 Feb 2022, 19:09
Thanks!
Aero loading makes it difficult to determine, the championship winning Renaults (during the Alonso years) had a pronounced rear weight bias, they seemed to work okay.
