2022 Winter Testing Part 1: Barcelona 23 - 25th February
Hoffman900
Hoffman900
220
Re: 2022 Winter Testing Part 1: Barcelona 23 - 25th February
I wonder if it’s something that be managed some with the shock valving and teams inexperience with ground effects are throwing them off.
Obviously it’s ultimately an aero issue.
dans79
267
also of note!
Autosport!
11:09 Amazingly, no stoppages or red flags in this opening day! Apart from a slight excursion from Max Verstappen in the gravel, everyone kept it clean.
202 105 104 9 9 7
McMika98
McMika98
-24
jjn9128 wrote:
23 Feb 2022, 19:11
McMika98 wrote:
23 Feb 2022, 19:09
JPower wrote:
23 Feb 2022, 18:40
Sounds like a few teams have porpoising issues.
Every car will have this especially on slow corners. The alpha tauri shakedown video had visoble pitching of the car.
It's a high speed behaviour?!
Seen the Gary anderson explanation, but i think slow corners after huge braking are prime candidate as the ground effect downforce could massively drop pitching the car back and forth.
Macklaren
Macklaren
dans79 wrote:
23 Feb 2022, 19:13
also of note!
Autosport!
and Lando had a brief pitlane stoppage (yellow flag only)
Dee
Dee
https://the-race.com/formula-1/mark-hug ... trackside/
Hughes said all the cars have issues with it, including the fastest ones
jjn9128
780
McMika98 wrote:
23 Feb 2022, 19:16
jjn9128 wrote:
23 Feb 2022, 19:11
McMika98 wrote:
23 Feb 2022, 19:09
Okay so there's 2 different behaviours - the high speed porposising is resulting from an aerodynamic stall when the ride height drops - the ride height then rises allowing the air to reattach - the ride height drops and stalls... etc
The low speed bouncing is more likely the tyre slipping and gripping. The stiffer sidewall tyres may make this more common.
#aerogandalf
Hoffman900
Hoffman900
220
Dee wrote:
23 Feb 2022, 19:19
So sounds like a lot of mechanical chassis issues to me.
More unsprung weight, plus stiffer suspensions to control pitch, less sidewall, etc.
I suspect a bit of the gains will be found in the shocks / set up.
Larger diameter wheels / tires should run over small dips / the curbs easier, but they also are likely prone to wandering in any amount of dips, especially in the braking zone.
It’s still not as extreme as a Datsun 510 that showed up to a race with the rear on the bump stops. It looked like a low rider going down the straight (and then the door blew off). :lol:
_cerber1
275
Marble
Marble
3 tables with today's data :
Henri
Henri
-6
McLaren are slow even on the red tire in s3 doesn't look good.. Mercedes look mighty on s1
Macklaren
Macklaren
Henri wrote:
23 Feb 2022, 19:40
ummmm...Lando was 2nd fastest in S3. Also, every driver was lifting off at the end of the laps so its very hard to make a determination of S3 times
dans79
267
Macklaren wrote:
23 Feb 2022, 19:43
Henri wrote:
23 Feb 2022, 19:40
he was on the softest tires, he probably should have been the fastest in sector 3!
202 105 104 9 9 7
Bisonas
If cars are having porpoising issues, I wonder how their kerb riding ability will be affected. Especially on some (of specific geometry) kerbs that exists on some tracks.
Hoffman900
Hoffman900
220
Guys, again, for the millionth time, lap times are useless. Today is about data collection for all the simulations; aero, suspension, PU, tire models, etc
__________
__________
LMAO are we really analyzing these test times? On day 1?
"Power is only given to those who lower themselves to pick it up" - Ragnar Lothbrok
