Not wires, they are air tubes for pressure sensors, so they are thick and can't make tight bends, they are only for testing and wouldn't be on during races.Sieper wrote: ↑23 Feb 2022, 18:46Quite impressive how they got everything to taper, and the huge floor surface next to the rear wheels because of it. They are more or less the only team that went for as much clear floor as you can get. With Mclaren a second. The rest all went with higher sidepods carrying on longer.
Curious to see what turns out to be the most beneficial. But it is clear a lot of thought has gone into this. Except for that bunch of white wires in the front of the sidepot
