Alpine A522
Iowa
Iowa
Re: Alpine A522
Looks like last year's car, Wing and air intake
toraabe
toraabe
Re: Alpine A522
If the engine went now, it's actually not that bad. I would have been worse if it occurred in the first race.
Jambier
Re: Alpine A522
toraabe wrote:
25 Feb 2022, 11:38
There is no link.
They already tell that engine is not reliable yet, so it can break at any race.
Which is not really an issue either, the important thing is to be fast.
AeroDynamic
349
Re: Alpine A522
#AMuS
Varusi_12
Re: Alpine A522
Some bbq here
RedNEO
40
Re: Alpine A522
That’s just a flesh wound compared to this side which experienced the full power of the bbq
Exclusive look inside the side pod
selvam_e2002
selvam_e2002
-1
Re: Alpine A522
Done for the day. Pack up and see you on Bahrain.
Re: Alpine A522
Hydraulics leak said Alpine.
dren
228
Re: Alpine A522
25 Feb 2022, 14:37
PU blood.
Honda!
RedNEO
40
Re: Alpine A522
25 Feb 2022, 14:37
@lawrobarretto
Alpine's Barcelona session come to an early end. They did 266 laps without the use of DRS & by running the engine on very low settings. They were limited on certain parts, too, so drivers drove well within themselves to avoid damage. Plenty more to come, then.
Re: Alpine A522
Will they have a bodywork update for Bahrain?
Beware of T-Rex
Re: Alpine A522
RedNEO wrote:
25 Feb 2022, 15:21
25 Feb 2022, 14:37
@lawrobarretto
DRS uses Hydrolics .
Re: Alpine A522
25 Feb 2022, 19:50
Fry said a Major upgrade for Bahrain and another for the race. They also had a floor update for day2 Spain.
Re: Alpine A522
I think this fall under Technical ...
https://it.motorsport.com/f1/news/f1-fr ... g/8516989/
Pat Fry, Alpine technical director, said he solved the porpoising problem that occurred on the A522 already on filming day. The Enstone team will be able to work with less fuel in the next tests, looking for performance.
Fry then explained how in Alpine they did to mitigate the effect of porpoising. This was a major advantage for Alpine's test program, although the team lost almost all of the last day due to a hydraulic failure that forced Alonso to stop on track after just doing 18 laps.
"How did we manage to cancel porpoising? It's about finding the correct aerodynamic balance of the car: you don't have to stress the aerodynamics too much. It's not exactly an easy thing: you need a compromise between what you can reach as maximum speed on the straight and what you can achieve. you can get in the fast corners ".
Alpine will now be able to focus on preparing the A522 for the Sakhir tests. Reliability will be needed in the first races of the season, especially after the 5 red flags seen in the first half of Friday. Then, as is always the case in F1, performance will be needed. The transalpines will be able to run with less petrol already in the last tests in Bahrain, because in a few weeks everyone will have to throw off their masks and get serious.
stan_french
stan_french
Re: Alpine A522
diffuser wrote:
26 Feb 2022, 20:40
I am an alpine fan boy, but this little article is at least nice to hear. Sounds like quiet confidence to my ears.
