The winglets on the rear wheels, do they move with the alignment of the wheel? If you toe in at the rear, and if the entire aero assembly moves with the wheel alignment, then you are moving the leading edge closer to the diffuser. With toe out, you would be moving the trailing edge closer to the diffuser.
With toe out, you also create stronger jetting vortices from the tire. The wheel furniture, and the alignment of the wheel works together to strengthen the airflow traveling along the side of the diffuser. The closer the wheel winglet is to the car body, the more that area can function like a nozzle.
holeindalip
holeindalip
godlameroso wrote:
Wed Feb 23, 2022 6:31 pm
https://i.imgur.com/dAaSj3T.jpeg
https://i.imgur.com/M2I2IXF.jpeg
https://imgur.com/yw0Zq3k.jpeg
https://pbs.twimg.com/media/FMRLxtaXwAM ... name=large
They would have to be mounted to the hub and move the same direction as the wheel as you say, or else any toe or camber adjustments with sidewalk flex would break them off. Correct me if I’m wrong…
AeroDynamic
333
Positive feedback from Verstappen and Albon about following other cars
https://www.racefans.net/2022/02/24/fol ... bon-agree/
I didn't know it was this bad!
====Zen level====
Thu Feb 24, 2022 10:29 pm
https://twitter.com/F1/status/149688866 ... et%3DTweet
It can be fixed!
mzso
mzso
50
Did everyone else had problems with porpoising? Is there footage of others?
I'm guessing those will be the fastest cars that successfully avoided the problem in their design. The others will need to resort to workarounds.
jjn9128
744
mzso wrote:
Fri Feb 25, 2022 9:41 am
Rumour is every team has it. Some sources say Mercedes have it worst others Alpine or Red Bull. I think it will be the cars with more aggressive underbodies suffering the worst. I had not expected this though - maybe naive of me to think the simulation tools would catch it.
#aerogandalf
djos
100
jjn9128 wrote:
Fri Feb 25, 2022 9:58 am
Joylon Palmer says Mclaren is the only team not suffering porpoising.
The impossible often has a kind of integrity which the merely improbable lacks.
jjn9128
744
djos wrote:
Fri Feb 25, 2022 10:05 am
But also that they're running their DRS on every lap - so reducing the overall load.
#aerogandalf
djos
100
jjn9128 wrote:
Fri Feb 25, 2022 10:38 am
Good point.
djos
100
Kyle’s RedBull analysis is up and it’s rather fascinating!
Peter Ian Staker
Peter Ian Staker
Teams are lobbying the FIA to bring back inerters to control porpoising.
https://www.formu1a.uno/rimbalzo-aerodi ... ospensivi/
Hoffman900
Hoffman900
121
Peter Ian Staker wrote:
Fri Feb 25, 2022 4:11 pm
Not sure if true, but I really didn’t understand banning these. I can find two dozen + cars at any serious amateur race weekend with them.
Hydraulic inerters? I don't see too much outside of the top end of motorsports using them, they can be tricky to tune.
I ran one for a while but setting up for every event was hit or miss sometimes, they could cause some odd load fluctuations if you didn't nail it.
Hoffman900
Hoffman900
121
PhillipM wrote:
Fri Feb 25, 2022 6:28 pm
You see them some of the higher end Formula and Sports Racer classes. Benefit of a prep shop is they have data across all the cars, but yes, it would be tough for an individual effort.
Also popular on the rear of Pro Stock and Pro Mod drag cars, but that application makes a lot of sense for them.
