Mercedes W13
.poz
.poz
51
Re: Mercedes W13
Shaddock wrote:
10 Mar 2022, 01:02
Chemicals such as barium hydroxide octahydrate and ammonium thiocyanate will freeze if they come into contact with each other for example.
That reaction (that after a fast research on internet seem to be one of the most endothermic) generates ammonia.... not very safe
But can you store in a F1 car a sufficient amount of it to "generate" enough cold to cool the car for a whole GP ?
240
Re: Mercedes W13
Emag wrote:
09 Mar 2022, 15:06
ringo wrote:
09 Mar 2022, 15:03
the EDGE wrote:
09 Mar 2022, 09:38
How exactly would you control tyre wake in an era with no no out-wash FW, no bargeboards... and no sidepods?
Not sure where this rumour came from... but I'm not buying it
This tyre wake control thing is actually the flavour of the month fad. Having no sidepods is the more beneficial thing to do.
The tyres already have the winglets above them by regulation. The cars do not have bargeboards any more to turn the air outward.
what they do have are tunnels.. very big tunnels and that's where most of the air that matters will be going.
Removing the side pods reduces lift and provides more high energy flow over the top of the floor and to the rear of the car.
The tyre wake thing only affects drag, doesnt produce downforce and will vary as the front wheels turn.
Tyre wake significantly alters the flow towards the rear for worse. It's not a good idea to leave it unmanaged.
The winglets on top of the wheels and covers help somewhat, but they don't nullify the problem.
If Mercedes doesn't do anything to mitigate the dirty air at least to a certain degree, it won't matter how much free space they have on top of the floor. If the dirty air hits the rear before the diffuser, it messes up everything.
And the fact that this wake is variable, as you said, changing with amount of steering input. That makes it even worse because not only is there a huge mess, it's an incosistent mess.
It is being overstated. The wake from the front tires had a bigger impact on the older cars with the flat floor and tea tray area.
The flow of air from the tyres further downstream is more outward. The tyre wake more affects leakage of air to the floor and drag. The leakage from the floor was more considerable with a flat floor.
These cars have tunnels so the flow is cupped under the car and sheilded.
Secondly a sidepod shape is not protrusive enough to signficantly alter the tyre wake.
It would literally have to reach out into the shadow of the front wheels.
The is a larger benefit of smaller sidepods.
What ferrrari and aston are doing is trying to reduce lift with the body of the car.
That was their goal more so than anything with tyre wake.
A flat topped sidepod has better pressure recovery after the air passes downstream of the radiator inlets.
Ferrari have been playing with this concept for years. However the balance of not starving the air flowing along the lower parts of the car to towards between the rear wheel and gearbox is usually compromised.
They now have this curved shape on the edges of the top of the sidepod to create a vortex that curls inward and brings air downstream.
I dont have the time these days to do the cfd and all my images of cfd on older cars are deleted as i was using image bucket back then.
But long story short. Going with a cigar shaped car and a big expansive floor and a few gurney flaps to build pressure on top of the floor will reap a lot of rewards.
SmallSoldier
SmallSoldier
486
Re: Mercedes W13
The new “no sidepods” of Mercedes
Vía Albert Fabrega
gandharva
gandharva
252
Re: Mercedes W13
SmallSoldier
SmallSoldier
486
Re: Mercedes W13
Another angle
NtsParadize
NtsParadize
Re: Mercedes W13
Madness
Envoyé de mon Nokia 8.1 en utilisant Tapatalk
LM10
LM10
122
Re: Mercedes W13
Looks crazy!
Re: Mercedes W13
Are there any pictures of the rear? Is it as slim as before?
This design is radical indeed. Very impressive!
SmallSoldier
SmallSoldier
486
Re: Mercedes W13
10 Mar 2022, 07:56
I’m sure we will get some in pretty soon… Will make sure to post (if I’m still awake! Lol)
NtsParadize
NtsParadize
Re: Mercedes W13
New vortex generators below the mirrors?
SmallSoldier
SmallSoldier
486
Re: Mercedes W13
Yes, completely different concept to the car in Spain (vortex generators on behind the mirrors)… Funny that Aston Martin copied the Barcelona ones for these tests, guess they will have these ones next week :)
NtsParadize
NtsParadize
Re: Mercedes W13
I remember how some people were saying here how "impossible" it was for Mercedes to bring a new car for the second test due to the cost cap lol
NtsParadize
NtsParadize
Re: Mercedes W13
And remember the sidepod design which didn't pass the crash test was said to be even more extreme
AeroDynamic
349
Re: Mercedes W13
lol that is bizarre. Well, I am not surprised they had a full hand!
Without question, that is a more radical step forward in development than we saw in 2019 between the two tests.
In the background, another car looks very similar to what we saw in test 1. :)
Re: Mercedes W13
It didn't dissapoint, i was expecting this info to be a bust but they really had their cards in their pockets.
