McLaren MCL36
Re: McLaren MCL36
17 Mar 2022, 22:12
17 Mar 2022, 21:50
Well. The ends of the lower contral arms could be stacked onto one stub and it not be multi-link any more... We would have to see the Wheel hub to confirm.
It would still be multilink no matter what. The centers of the spherical bearings are offset in space.
Look carefully and you see that the rear arm has a cup shape at the end where it seems the bearing of the leading arm sits into it. Could be effectively functioning like one A-arm.
Re: McLaren MCL36
17 Mar 2022, 22:41
17 Mar 2022, 22:12
17 Mar 2022, 21:50
If these two arms were meant to bolt together like "one A-arm", they would have instead made a single piece ( > ) wishbone for the lower control arm because that would have only required 1 bearing and would therefore be consequentially lighter. This happens to be exactly what they have done for the upper control arm. If there are two separate bearings/links, it's because they mount in different places to create a virtual endpoint for the kingpin axis.
The "cup shape" thing is a spherical bearing.
#ReleasetheADUO
luke352
luke352
Re: McLaren MCL36
MrGapes wrote:
17 Mar 2022, 11:17
So what I can interpret from this is, the silicone was used to absorb the heat that was leaking from the sides, this solution shrouds that area to reduce or stop leakage into the cake tins, anyway that's a pretty significant alteration.
That's standard High temp RTV. I'd suspect with the amount on messing around they were doing with the brakes the normal gaskets were stuffed so they were just slathering on RTV to try and keep it sealed as best as possible to get through testing.
_cerber1
296
Re: McLaren MCL36
By @AlbertFabrega
f1rules
f1rules
634
Re: McLaren MCL36
new above old below
only picture of the car i could find on the way to fia
f1rules
f1rules
634
Re: McLaren MCL36
thanks to Matthew, this is what Mclaren brought beside brakes updates, so no big things
Matthew Somerfield 🅢🅞🅜🅔🅡🅢Ⓕ①
@SomersF1
1m
Replying to
@m_rosquist
▪️ Sidepod shoulder louvres
▪️ Floor fences
Re: McLaren MCL36
AeroDynamic wrote:
18 Mar 2022, 12:26
Nice view from within the MCL36
https://video.twimg.com/amplify_video/1 ... mp4?tag=14
Driver's helmet camera is a great thing and more of this should be done. That view shows that the mirrors are actually pretty useful and a driver can definitely see a car directly behind him and behind either side of his rear wheels.
Emag
Emag
137
Re: McLaren MCL36
f1rules wrote:
18 Mar 2022, 07:36
new above old below
https://cdn-1.motorsport.com/images/mgl ... ani-1.webp
Where are the mirrors?
Developer of F1InsightsHub
mwillems
Re: McLaren MCL36
Emag wrote:
18 Mar 2022, 12:48
f1rules wrote:
18 Mar 2022, 07:36
new above old below
They are pushed in for parking.
-Bandit
mwillems
Re: McLaren MCL36
f1rules wrote:
18 Mar 2022, 12:43
@SomersF1
1m
Replying to
@m_rosquist
▪️ Floor fences
Is this from observations on the car or from sources within the team? I'm wondering if it rules out new parts appearing for FP2?
I kind of expected a little more in terms of updates from this race, but perhaps the brake duct issue stunted that a little.
-Bandit
thestig84
16
Re: McLaren MCL36
The race are reporting new sidepods
https://t.co/FDrj5FDGGv
kalinka
kalinka
Re: McLaren MCL36
mwillems wrote:
18 Mar 2022, 13:16
f1rules wrote:
18 Mar 2022, 12:43
@SomersF1
1m
Replying to
@m_rosquist
▪️ Floor fences
There is a "show and tell" obligation for teams to announce upgrades/changes before the weekend starts, so it's all official now
MrGapes
34
Re: McLaren MCL36
thestig84 wrote:
18 Mar 2022, 13:19
maybe thats why they broke curfew??
FittingMechanics
FittingMechanics
Re: McLaren MCL36
thestig84 wrote:
18 Mar 2022, 13:19
is probably why The-Race says sidepods.
f1rules
f1rules
634
Re: McLaren MCL36
its what we saw in testing already on the last day in the evening, new mirror mount and flow conditioner next to the cockpit
