NL_Fer
NL_Fer
82
A burned cover on the side of Gasly. Max engine braking problems and derates. Perez lockup under breaking.
I think MGU-K or CE error
isullivan
isullivan
Didn't look like an ICE failure though.
The hydraulic pumps are breaking on the camshaft drives again, same issue as testing, they thought they'd fixed it, this is really not good, especially on so many cars at similar times it's a fatigue/design issue in the part not just a flaw.
Juzh
161
PhillipM wrote:
20 Mar 2022, 18:47
Yeah I'm thinking something hydraulics related as well, because they also run power steering and Verstappen was reporting less and less steering assistance. I suspect this pump in not part of engine freeze?
djones
djones
If its a fuel pump failure can that be replaced without going against any of the usage limits?
isullivan
isullivan
Isn't the fuel pump a standard component for all teams ?
Jaisonas
Jaisonas
isullivan wrote:
20 Mar 2022, 19:23
I think the in-tank pump is, not sure about the one on the engine though.
Watto
Watto
Juzh wrote:
20 Mar 2022, 18:59
PhillipM wrote:
20 Mar 2022, 18:47
Horner suggested the steering issues were Max seem to be because of the car being dropped at the pit stop likely a bent trackrod, it effected turning one way more than the other, Max said it was something that happened at the pit stop but not sure what
vorticism
vorticism
449
PhillipM wrote:
20 Mar 2022, 18:47
Why this season? What do you think changed?
chrisc90
_cerber1
301
Has the extra weight made itself felt? Decided to fill in less fuel, which led to overheating of the pump?
Big Tea
_cerber1 wrote:
20 Mar 2022, 20:20
Higher water content in E10?
vorticism
vorticism
449
Big Tea wrote:
20 Mar 2022, 20:24
_cerber1 wrote:
20 Mar 2022, 20:20
Makes me think...
>Standard fuel pump
>Non-standard fuels
>Non-standard engine temperatures and vibrations
Then 3/4 of the Hondas are out of the race.
Big Tea
vorticism wrote:
20 Mar 2022, 20:39
Big Tea wrote:
20 Mar 2022, 20:24
_cerber1 wrote:
20 Mar 2022, 20:20
Makes me think...
>Standard fuel pump
>Non-standard fuels
Is anyone else using the same fuel as RB?
Vibration does make more sense though. Is electric or engine driven?
chrisc90
vorticism wrote:
20 Mar 2022, 20:39
Big Tea wrote:
20 Mar 2022, 20:24
_cerber1 wrote:
20 Mar 2022, 20:20
Makes me think...
>Standard fuel pump
>Non-standard fuels
I dont think Gasly's breakdown was related to the fuel pump
