CFD - 2022 F1 Car
Contact:
Re: CFD - 2022 F1 Car
Tom888 wrote:
19 Mar 2022, 18:46
Where is throat located in 2022 cars, I expect here lowiest pressure?
Is there any real picture of undertray of these cars?
You'll have to look at car threads for that, haven't seen good photos so far. :)
#Aerogimli
Likes_race_cars
What a fantastic post, not sure i understand even half of it. This is good stuff.
Fluido
Vyssion wrote:
17 Dec 2019, 14:38
Very similar setup to the Perrinn model; straight ahead solve here, no crossflow or curved flow, steady-RANS w/ SST turbulence inc. wall functions, 31.5million elements, etc etc...
How number of cells affect accuracy, if you use high resolution grid(more cells), results will be closer to real one?
Stu
Fluido wrote:
26 Mar 2022, 13:06
Vyssion wrote:
17 Dec 2019, 14:38
More cells do create greater accuracy, but require a longer calculation time. Even the teams rationalise cell count; before increasing resolution where it is required.
Fluido
Stu wrote:
26 Mar 2022, 14:05
What does it mean, only super computers can do real results?
Can our "home computers" gives correct results or calculation would take a couple of years to have correct resluts?
CAEdevice
45
Contact:
Fluido wrote:
26 Mar 2022, 18:51
Stu wrote:
26 Mar 2022, 14:05
I depends on the data you are looking for.
Fluido
CAEdevice wrote:
26 Mar 2022, 19:37
Downforce at front/back wheels(within 20N accuracy), static pressure distribution at all parts of car body, position of center of pressure,overall drag, separation point at undertray, cofficient of pressure change in relation to speed(Re number),accurately predict vortex paths at undertray, find thickness of boundary layer at every point of body.. at F1 car
CAEdevice
45
Contact:
Fluido wrote:
26 Mar 2022, 20:05
CAEdevice wrote:
26 Mar 2022, 19:37
All together? You would need K*10^7 cells. At this point, I would not neglect a transient simulations. Yes, you need something more than a desktop. Even with a multi xeon machine tens of hours would be required.
johnny comelately
110
What do you aero chappies think of bullet point 2?
"Doug McLean (Boeing)| Common Misconceptions in Aerodynamics"
johnny comelately
110
Fluido
Stu wrote:
26 Mar 2022, 14:05
jjn9128 wrote:
29 Jul 2020, 17:22
Where is your autosave, backup folder from CFD and CAD, on SSD or HDD?
Isnt bed to write so much on SSD and I have small SSD, but if I put on HDD will program run slower?
jjn9128
769
Fluido wrote:
04 Jan 2024, 13:26
Stu wrote:
26 Mar 2022, 14:05
jjn9128 wrote:
29 Jul 2020, 17:22
Without the quote I've no idea what you're asking.
#aerogandalf
Fluido
jjn9128 wrote:
04 Jan 2024, 15:13
Fluido wrote:
04 Jan 2024, 13:26
Stu wrote:
26 Mar 2022, 14:05
jjn9128 wrote:
29 Jul 2020, 17:22
My question is not related to any quote..
If I just write @username you will not be notified...
Fluido
Vyssion wrote:
17 Dec 2019, 14:38
G'day! It's been a while... hasn't it? :)
With the 2019 season now concluded, and jjn and I being in stage 4 withdrawals right now, we figured that we needed "something" to keep our mi... ooooooo!! Is that the 2021 regulations??? :lol:
So, without further ado, I would like to present to you all our first, and legal (to the best of our knowledge), 2021 spec. F1 car!! And the first car that is wholly of F1T design!!
-sigh-... who would have thought that Aerosaruman and Aerogandalf would ever work together again, huh? =D>
https://imgur.com/PYnaTVH.png
https://imgur.com/guOyb4N.png
https://imgur.com/IeQhAHn.png
So.......
What forum post from Vyssion would be complete, without some CFD: COLOUR FOR DIRECTORS!!
https://imgur.com/P6ED0ny.png
https://imgur.com/5R58Ahv.png
https://imgur.com/ThzSwAg.png
Here is a list of bullet points that, so far, we have twigged, and are gonna work on next. Now I am gonna shamelessly make excuses for any "iffy" performance or flow features you see, because... IT WAS OUR FIRST GO AT IT, OKAYYYY?? :cry: Overall, for a first go at it, the car performs very, very well; hats off to jjn.
  • CzS = -4.95
  • CxS = 1.80
  • Front Wheel wake is pretty crazy now... we will work on this
  • Going to reduce pitch setting of FW flaps
  • Inboard floor fence vortex isnt under control (just spreads out)
  • 2021 Force Breakdown = Floor (50%), FW (37%), RW (25%)
  • Compared to Perrinn = Floor (55%), FW (30%), RW (40%)
  • Higher than 100% is due to Lift generated on the chassis and wheels (6% lift on 2021 wheels, 9% lift on Perrinn)
  • Balance of 2021 is ~49% which is quite far forward, so we will correct this (starting with FW flaps as mentioned above)
  • Surprisingly large amount of low pressure below the car
  • Front suspension is stalled
  • Top of floor inlet is stalled
  • Rear of Lower sidepod expansion has stalled
  • RW flap stalled in curved EP sections (and slightly along TE) and RW as a whole is very draggy
-edit- replaced old gifs with larger ones - I made a mistake when I was creating them... oopsies
https://imgur.com/s0WIUwj.gif
https://imgur.com/rUTxoyq.gif
https://imgur.com/KYFQvuG.gif
https://imgur.com/2faOvGm.png
https://imgur.com/1wXjL5V.png
https://imgur.com/zTHRlNz.png
https://imgur.com/zueL8hT.png
https://imgur.com/bBaIjl3.png
https://imgur.com/9fPR6mf.png
https://imgur.com/kLcnClK.png
How much is project size of CFD and CAD ?
Zynerji
111
I have an odd question for the CFD folks.
Does any team actually model the chassis vibrations and energy lost to noise during these runs? Or is even the most extreme cases still modified approximations?
I'm sure it's a ton more complex, and probably very minimal in its helpfulness, but I would expect it could become necessary as the aero gets more knife-edge.
