Mercedes W13
Re: Mercedes W13
SirBastianVettel wrote:
29 Mar 2022, 19:59
29 Mar 2022, 19:27
Something else got me thinking.
Sauber has made their own rear gearbox, but are the suspension components theirs or Ferraris? Hard to believe a Sauber suspension is more advanced than a Mercedes one? Just pondering how much weight must be put to suspension as the root cause.
In the SA Tech Talk episode on F1TV there was an interview with Jan Monchaux from Sauber and they said they don't use the Ferrari rear suspension.
The components is what I refer to. For example Sauber can have a different configuration of wishbones and rockers etc but the dampers other valves, bars and other mechanisms could be a Ferrari specification. Those little components could be the difference in porpoising or not.
Curious if anyone can confirm if these components are Ferrari related.
vorticism
vorticism
347
Re: Mercedes W13
dans79 wrote:
29 Mar 2022, 22:30
vorticism wrote:
29 Mar 2022, 21:22
Why did they test two types of sidepod? Just to have something to compare against?
In Barcelona they ran an early revision of the w13 that was most likely finalized last year, maybe even before the season was over. What they ran in Bahrain was a later revision, most likely finished as late as possible.
I wonder if the underlying monocoque is the same or not. The big changes would be potentially be radiator placement, impact structures, fuel cell shape. The nosecone, halo, airbox, all that stuff seemed the same/interchangeable between the two versons. Maybe the Barcelona chassis was already in manufacture during 2020.
dans79
267
Re: Mercedes W13
vorticism wrote:
30 Mar 2022, 01:02
2020?
202 105 104 9 9 7
vorticism
vorticism
347
Re: Mercedes W13
dans79 wrote:
30 Mar 2022, 01:17
vorticism wrote:
30 Mar 2022, 01:02
2020?
I'm not sure when the rules delay happened nor whether or not that was before or after they started building the next season's cars.
holeindalip
holeindalip
Re: Mercedes W13
vorticism wrote:
30 Mar 2022, 01:02
dans79 wrote:
29 Mar 2022, 22:30
vorticism wrote:
29 Mar 2022, 21:22
Mercedes have already confirmed the underlying hardware are the same/same placement as Barcelona. Just the outer bodywork is different…
zibby43
zibby43
Re: Mercedes W13
zibby43
zibby43
Re: Mercedes W13
Suspension responsible for porpoising, via Scarbs:
atanatizante
129
Re: Mercedes W13
GP blog says they`ll have a new rear wing for Australian Grand Prix, quoting AMus and a Merc engineer: https://www.gpblog.com/en/news/107477/m ... -wing.html
Does that mean they already have a new front wing or just alter/set up it in order to balance the new rear wing?
Jesus
pursue_one's
97
Re: Mercedes W13
atanatizante wrote:
30 Mar 2022, 13:14
Mercedes' engineer says:
“Don't look at the surface of the car and the rear wing flap. This is misleading. Air resistance mainly generates the skin blade of the rear wing and the lower wing in the rear, and there we are high up.”
Mercedes will bring a new rear wing to Australia because of their problems with drag.
Henri
Henri
-6
Re: Mercedes W13
Hope the upgrades work.. car should gain 3 to 4 tenths just by reducing the weight to the minium spec
matteosc
matteosc
30
Re: Mercedes W13
A little presumptuous to claim to "lap the entire grid", but it looks like they are one race ahead of the initial plan. After Melbourne we should know if they were able to fully understand the problem.
InsaneX_Badger
Re: Mercedes W13
Think the lap the grid is made as a joke. But I doubt it will give these dividends. Will it catch them up to the front two if they work, certainly. But both Ferrari and red bull won't be standing still with them both smelling championship glory.
Re: Mercedes W13
That's not an official MB twitter, it's a Mercedes fan account so don't take any of it seriously.
matteosc
matteosc
30
Re: Mercedes W13
Yes, I know it is not official, but all other points are perfectly credible and serious.
Watto
Watto
Re: Mercedes W13
matteosc wrote:
30 Mar 2022, 15:14
Just_a_fan wrote:
30 Mar 2022, 15:12
matteosc wrote:
30 Mar 2022, 15:08
This from Scarbs to someone that tagged him about that
His suggestion is Merc main thing they need to fix it the suspension first.
So he casts some doubt on it, at least whether it will address the main problem
