Aero analysis for F1 2022 based on CFD result
Re: Aero analysis for F1 2022 based on CFD result
Fluido wrote:
12 Apr 2022, 21:07
godlameroso wrote:
12 Apr 2022, 16:01
The strakes at the front are basically static fans, they push air outward instead of letting it go rearward, less airmass means less air pressure. Less air pressure means more acceleration of upstream air, more momentum, means less static pressure(up to a point).
Dont agree with this logic, if you want less airmass than you can simply put plate to the ground at front bumper and stop airflow completly.
Idea is to increase airflow under car not decrease.
Maybe they use vanes to produce vortices to seal side of flor, because they cant use skirts that touch road...
What happens when you increase the airflow under the car? Does the pressure in a balloon go up or down if you increase the airflow into it? Also putting a plate to the ground is 1, not allowed, 2, doesn't work because the air will spill in from any gap. 3, If you stop the air from flowing, you slow it down and raise its static pressure.
620
Fluido wrote:
12 Apr 2022, 21:15
godlameroso wrote:
12 Apr 2022, 16:53
I imagine aero yaw forces could work to increase or decrease inertia of the vehicle.
You are violate basics physics axioms.
Inertia is the property of mass, not aerodynmic forces.
there are such things as added mass effects
Fluido
godlameroso wrote:
12 Apr 2022, 21:45
Airflow in ballon is allways zero, air is not moving..so question is wrong
For sure if you stop airflow under the car ,static pressure will rise
Vanja #66 wrote:
12 Apr 2022, 20:07
godlameroso wrote:
12 Apr 2022, 18:21
When I put it back together, sure.
Good luck with that!
Until then, you might want to contemplate on a few things.
godlameroso wrote:
12 Apr 2022, 16:53
while weight is increased inertia is not
If inertia of the car is not increased with downforce (ie just mass in this case, ie weight) meaning the braking force doesn't have to deal with more mass to produce the same deceleration and should be better with increased drag (which inevitably comes with aero package), why is the braking worse? Could the aero balance be too much on the rear axle, unloading the front and decreasing front tyre traction - leading to poor braking performance?
godlameroso wrote:
12 Apr 2022, 16:53
I could use more power, I'm pretty much flat through turn 1
If you are flat out, ie power limited, what is causing it? Could it be drag?
How come increased weight with downforce doesn't push you out of the corner? Is it maybe not an increase in weight, but rather an increase in vertical load? (weight is a type of vertical load, but not every vertical load is (a) weight)
godlameroso wrote:
12 Apr 2022, 16:53
How can any external force change the inertia of the car, ie change its mass, center of mass and/or mass distribution? (parts flying of the car is not what I'm pointing at)
If the inertia doesn't actually change, could the aerodynamic side forces influence the behaviour, ie car dynamics?
Braking is worse because the drag and aero forces increase the braking capacity and my little single piston calipers can't use all the braking grip available. I'm cracking rotors, bending pads, and boiling fluid. The mass of air acting on the car is producing that drag, the effect is basically that of a heavier car on the stock components. My braking distance is shorter, obviously, and because I can brake much deeper into corners, and can trail brake harder, I need bigger brakes to take advantage of the extra grip.
An external force acting on the car is adding more weight to the suspension. Air is a physical object it has mass, force = mass times acceleration right? Aero forces are the result of air mass accelerating and decelerating over an object. Just like a vertical stabilizer on the plane resists side thrust and thus adverse yaw, and the horizontal stabilizer produces downforce to resist the nose up attitude on a plane. So too does the end plate resist side thrust and thus increases the inertia of a vehicle on turn in.
Fluido wrote:
12 Apr 2022, 21:56
godlameroso wrote:
12 Apr 2022, 21:45
Ok, so we agree the air has to keep moving, and why does the air have to keep moving? Because if it slows down, static pressure rises. Which means fast moving air is low pressure, why is it low pressure? Because the air spends less time bouncing against the walls and thus exerts less pressure on them. If we reduce the air mass, the effect is similar, less air molecules to interact with the walls and exert pressure.
Fluido
Maybe this toys can show undertray?
Fluido wrote:
12 Apr 2022, 22:03
https://www.cdn-docs-ck.com/docs/bilde ... 309805.jpg
If you have Assetto Corsa, you can look at the undertray of 3 LMP1 cars and a bunch of Ferrari F1 cars in the showroom. They're legit as the models were made with the original CAD drawings.
Fluido
godlameroso wrote:
12 Apr 2022, 22:02
Which means fast moving air is low pressure, why is it low pressure? Because the air spends less time bouncing against the walls and thus exerts less pressure on them. If we reduce the air mass the effect is similar, less air molecules to interact with the walls and exert pressure.
Wrong.
Speed does not produce low pressure, increasing(accelerating) it does.
If speed produce low pressure, aircraft altimeter(he read static pressure from static port) will read higher and higher altitude as aircraft speed up, even if fly in horizontal line..
http://www.prirodopolis.hr/Bernoulli-Co ... noulli.mp4
Fluido wrote:
12 Apr 2022, 22:32
godlameroso wrote:
12 Apr 2022, 22:02
Wrong.
What if you're accelerating air into the side of a barn, does the pressure go down or up?
vorticism
323
godlameroso wrote:
12 Apr 2022, 21:58
Fluido wrote:
12 Apr 2022, 21:15
godlameroso wrote:
12 Apr 2022, 16:53
Air has no mass then?
Lift does not increase the mass of the wing. Barn drafts would have a negligible effect on the weight of the air inside the barn. There are generally not air pockets of considerable size within wings, even if there were, fluctuations in air mass within them would be negligible as a bouyant lifting force compared to aerodynamic lift.
𓄀
Fluido
godlameroso wrote:
12 Apr 2022, 22:36
Fluido wrote:
12 Apr 2022, 22:32
godlameroso wrote:
12 Apr 2022, 22:02
Wrong.
What is side of barn?
English is not my mother language..
vorticism wrote:
12 Apr 2022, 22:40
godlameroso wrote:
12 Apr 2022, 21:58
Fluido wrote:
12 Apr 2022, 21:15
Lift is a force, the force is generated by air pressure, pressure is a result of mass x acceleration. If air had no mass, there would be no aerodynamic forces, period. If I sit on you, you have more pressure on your back, gravity is accelerating me over you, and you experience a downward force. Downforce is the same thing except less dense.
vorticism
323
godlameroso wrote:
12 Apr 2022, 22:50
Correct. However you are claiming that a gas (atmosphere in this case) can imparting mass to a solid object passing through it.
𓄀
vorticism wrote:
12 Apr 2022, 22:58
godlameroso wrote:
12 Apr 2022, 22:50
Well any object that passes through the air has stagnation regions, those stagnation regions, and areas of relative high pressure are exerting the pressure from their static air mass on the solid object passing through it.
Remember the air is pretty much still, save for any gusts, it's the car that's moving, which is the opposite of a wind tunnel, and somehow a wind tunnel is an essential tool.
Wow, this thread is totally messed up now. For a technical thread, there's a lot of hocus pocus being spouted.
