The Road to the 50% Thermally Efficient F1 Internal Combustion Engine
vorticism
323
Re: The Road to the 50% Thermally Efficient F1 Internal Combustion Engine
johnny comelately wrote:
28 Apr 2022, 09:19
This is our old test mule showing the dual flame jet ignition where it was cast welded inserts and went too lean (methanol) causing the burn out/in on one cylinder. Unconventional engine design, dont ask
3 mm holes, 94 mm bore
https://images-wixmp-ed30a86b8c4ca88777 ... tOt0o2XJq0
Where are the valves? Two stroke?
𓄀
gruntguru
563
Looks like a (Bishop?) rotary valve.
vorticism
323
Not Bishop. Starts with a D... I'll let johnny explain. :)
𓄀
johnny comelately
110
vorticism wrote:
29 Apr 2022, 00:45
I said "dont ask" LOL
not a D (for Dunstan) either
But let us not digress, the point is the flame ignition (which works so well)
But there you have it, too lean, from memory maybe around 1
supercharged to 15 psi
The immediate problem was the inserts were cast.
the second thing I was trying to show was engine functioning and integrity in environs of 1.4 lambda is a huge challenge
vorticism
323
It's too late, you've piqued interest. If not a Dunston then... some proprietary work? A sliding valve maybe?
𓄀
johnny comelately
110
vorticism wrote:
29 Apr 2022, 00:54
It's too late, you've peaked interest. If not a Dunston then... some proprietary work? A sliding valve maybe?
Rotary.
I'd rather have peak interest in the F1 engines LOL
So if I may, the 3.5 bar coolant pressure gives a boiling point of 135 C ??
Giving a coolant temp of 115C maybe
J.A.W.
109
29 Apr 2022, 01:01
vorticism wrote:
29 Apr 2022, 00:54
Rotary.
Maybe this will pique your interest, 120C boiling point @ ambient pressure, Glycerine-based:
https://888chemicals.com.au/wp-content/ ... t_MSDS.pdf
johnny comelately
110
J.A.W. wrote:
29 Apr 2022, 01:43
29 Apr 2022, 01:01
vorticism wrote:
29 Apr 2022, 00:54
Rotary.
Interesting it is for beer (making)!
Is there a rule in F1 for coolant type??
vorticism
323
29 Apr 2022, 01:56
New rule: all fuels must be edible. Spirits and cooking oils only. Walnut oil vs vodka. Avocado oil vs cachaca. Olive oil vs ouzo.
𓄀
johnny comelately
110
vorticism wrote:
29 Apr 2022, 03:01
29 Apr 2022, 01:56
I do like the way you think :wink:
johnny comelately
110
Any header tank used on the car with a water based coolant must be fitted with an FIA approved pressure relief valve which is set to a maximum of 3.75 bar gauge pressure.....
my mistake on the 3.5 bar
any input on the coolant temp???
gruntguru
563
As high as possible while keeping:
- Temp of aluminium alloy parts
- Lube temp
- Detonation
. . . . .under control.
johnny comelately
110
On the performance side, I still am thinking it is to reduce the quench affect.
At this stage I will stick with the 115 C.
Along with the aid in atomisation (is that old word still allowed?) and hence temp drop.
If anyone has access to a university subscription, this is sort of relevant:
https://www.jstor.org/stable/44632864
johnny comelately
110
With this design as the status quo, imagine where young designers will take us when they dont carry the bias from the last millenium.
vorticism
323
29 Apr 2022, 13:03
Bias is inevitable, and history is only escaped via ignorance.
I don't think the current F1 engines will be a standard outside of top shelf motorsport. The rules force niche solutions which don't seem to be in line with automakers nor the less monied majority of motorsport activity. A fascinating novelty, yes, always, but as a benchmark I'm not sure.
𓄀
