Mercedes W13
AA_2019
AA_2019
Re: Mercedes W13
Sierra117 wrote:
06 May 2022, 14:38
AA_2019 wrote:
06 May 2022, 14:19
Sierra117 wrote:
06 May 2022, 12:21
I am just the messenger. You are free to believe it's not :)
That is not a Skate
The Skate should touch the ground when the car bottoms, skate along the ground (like ice skating boots), largely preventing the car floor from touching the ground and/or the plank wearing out.
The skate needs to be a metal of some sort as it will wear out
Yes, it is a metal plate. As I said, I am literally conveying a message, but as I said, you're free to tell the team(s) they're wrong.
Maybe you guys are just not seeing it. It's a small ... skate, literally. Look at other angles maybe and you can't miss it then.
We all see it, but it cannot perform the function of a Skate, there are parts of the floor that are closer to the ground. A skate will be the first thing to touch the ground.
KeiKo403
KeiKo403
Re: Mercedes W13
It’s more of a strake than a skate, imo.
Re: Mercedes W13
Stu wrote:
06 May 2022, 07:57
Blackout wrote:
06 May 2022, 07:54
morefirejules08 wrote:
05 May 2022, 23:25
W13 floor
https://i.imgur.com/Cj7Xigl.jpg
Wow! Look at how much they are trying to outwash at the tunnel exits!!!
I believe they radius the top of the diffuser to make space for air flow around the rear brake ducts. If they didn't it would be a massive pinch point. And we know from the Force india brake duct gate rhat the brake ducts are crtically important to car performance.
The reast of the walls are vertical though.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
F1Krof
94
Re: Mercedes W13
06 May 2022, 17:14
Stu wrote:
06 May 2022, 07:57
Blackout wrote:
06 May 2022, 07:54
Still the floor looks rudimentary comapred to some of the other teams. No cuts, no coutout flaps, no undulation...
Wroom wroom
AeroDynamic
349
Re: Mercedes W13
amarques
amarques
Re: Mercedes W13
Hey guys stop please!
I don’t care if it’s a skate… because I don’t understand that!
Important point is: Do you believe this will bring good progress?
KeiKo403
KeiKo403
Re: Mercedes W13
AeroDynamic wrote:
06 May 2022, 18:17
Should we consider this a small update? I know if they’re trying to correlate wind tunnel/cfd results then then they can’t afford big bang updates but will these upgrades really produce enough of a difference given the assumption that the issue lies with the floor flexing too much and the suspension (something wrong with suspension)?
matteosc
matteosc
29
Re: Mercedes W13
KeiKo403 wrote:
06 May 2022, 18:54
Rear wing and beam wing are just circuit-specific parts, not really an "update". Front wing endplates are instead a small update, in my opinion. Not really anything that will fix the fundamental problems of the car, which still need to be fully understood.
Re: Mercedes W13
amarques wrote:
06 May 2022, 18:29
Not the forum for you then. This is a technical forum where every detailed is pored over. Even the weave direction of the carbon fibre is analysed.
LxVxFxHxN
SuperCNJ
SuperCNJ
Re: Mercedes W13
Hmm, so no new floor or suspension parts. I guess we can expect the porpoising to continue then.
AeroDynamic
349
Re: Mercedes W13
New spec front wing end plate
Other spec
JordanMugen
82
Re: Mercedes W13
AeroDynamic wrote:
06 May 2022, 19:46
Is that allowed, I thought the elements had to join the endplate? :?: :)
That design with a free-edge will obviously generate a stronger vortex, but I thought the rules were intended to prevent that?
wogx
60
Re: Mercedes W13
There is no free edge, there are two metal joints
AeroDynamic
349
Re: Mercedes W13
Tvetovnato
Tvetovnato
Re: Mercedes W13
From the onboards, it looks like no porpoising right now (no sounds of it either)…
