Aston Martin AMR22
NAPI10
NAPI10
Re: Aston Martin AMR22
Swed3120 wrote:
19 May 2022, 14:41
Nice to see that Aston Martin is back to their 2020 ways of simply copying what is fastest and not even attempting to stick with their own design , so far they’re the only Team to really admit they completely screwed the new regs
Before AMR22 hit the road, team admitted working on B-Spec.
There has to be something wrong or extremely challenging with the original concept.
continuum16
51
Swed3120 wrote:
19 May 2022, 14:41
On face value yes that appears to be their direction, but nowadays the radiators and internals don’t necessarily fill the entirety of the sidepods, so there is still a chance that they will be different to others on the grid…
- Mark Twain
Looks like a floppy floor was the compromise of the pontoon style pods. A compromise like that is too big to make with a ground effect floor.
AeroDynamic
349
RB sidepods! And also the same layout of cooling louvres as the RB18. Also a similar looking edge to the floor! :D
Emag
Emag
113
Pretty much exactly likeRedBull sidepods.
Developer of F1InsightsHub
BlueCheetah66
BlueCheetah66
33
I didn't expect it to be a literal copy. I thought it would just be of a similar philosophy. It even has the changes RB made to it in Bahrain
michl420
michl420
BlueCheetah66 wrote:
19 May 2022, 18:25
The team proof again they are world champion in copy. :twisted:
GrizzleBoy
GrizzleBoy
33
Wow. Will be extremely interesting to see how it works on track!
If it has mad porpoising it willay end the floor vs suspension porpoising cause debate once and for all.
GrizzleBoy wrote:
19 May 2022, 18:31
Yes that is a great point. Well once again I have to thank tracing point because even though I look down on it, it's providing thoroughly interesting technical talking points :D
SmallSoldier
SmallSoldier
486
New AM22 at Spain, seems to follow the RB philosophy
Via: AMUS
BlueCheetah66
BlueCheetah66
33
Its not even just the sidepods they copied, the floor is near enough the same aswell
CaribouBread
CaribouBread
101
Should be a nice point of comparison for over-body aero's effect on bouncing as well as seeing how 'low drag' the RB concept really is (given AM can run the car lower than before :D )
quick edit; didn't realize they managed to copy the floor too :wtf:
SmallSoldier
SmallSoldier
486
They are definitely good at copying another team… They went for every detail they could:
Via: SalaStampa
Using 2 of the 4 tunnel entrance strakes to manage the front tyre wake too! Basically just a cut and paste job
