Mercedes W13
siskue2005
70
Re: Mercedes W13
214270 wrote:
20 May 2022, 22:17
siskue2005 wrote:
20 May 2022, 19:51
KeiKo403 wrote:
20 May 2022, 19:33
https://pbs.twimg.com/media/FTIs9elaIAA ... ame=medium
Could this part flex down and act like a skirt sealing a section of the floor? We’ve been thinking for a while that floors flexing were a bad thing but could Merc be gaining a benefit from it here?
If it wasn’t going to flex downwards and make contact with the surface of track then why make so much of the edge out of a metallic material and not go full carbon? Unless it’s because they don’t want it to flex?
it flexes upwards when it hit the track, hence preventing porpoising
Downwards surely? The fixings are no different to how the front wing elements are mounted. You’d fix from the underside if you wanted it to bend up
from the looks of it in this picture its being fixed by the hinges from underneath
AeroDynamic
349
Re: Mercedes W13
The W13 at high speed, DRS, down the straight. Floor looking flush to the ground. No porpoising was reported by either driver on the straights today.
close up with shadow detail
16
Re: Mercedes W13
siskue2005 wrote:
20 May 2022, 22:22
214270 wrote:
20 May 2022, 22:17
siskue2005 wrote:
20 May 2022, 19:51
https://serving.photos.photobox.com/941 ... 422d2a.jpg
Fair enough, the overhead made it look otherwise
siskue2005
70
Re: Mercedes W13
AeroDynamic wrote:
20 May 2022, 22:24
https://i.imgur.com/MxHSI7t.jpg
https://i.imgur.com/PZax51j.jpg
it looks so sleek when its not bouncing
AA_2019
Re: Mercedes W13
AeroDynamic wrote:
20 May 2022, 22:24
Purpoising was occurring on the high speed corners, lots of bottoming can be heard on the onboard video. This will give them high tyre wear on turns 3 and 9.
It's nice to be complaining about this as it means we are thinking of the smaller details that put us just out of touch of a potential win.
We are close for real this time.
Shrieker
Re: Mercedes W13
siskue2005 wrote:
20 May 2022, 22:51
Reminds me of the mp4/4, that shot.
Or maybe, it's just me :lol:
-Atatürk
AA_2019
Re: Mercedes W13
At 9 seconds in the video, slow playback down to 0.25x and you can clearly see the heavy purpoising at turn 3
Re: Mercedes W13
AA_2019 wrote:
21 May 2022, 00:33
Doesn't look like porpoising but rather like a car driving over bumps in the track surface.
AA_2019
Re: Mercedes W13
wesley123 wrote:
21 May 2022, 01:03
AA_2019 wrote:
21 May 2022, 00:33
I wish that was true, but if you look at the rear diffuser area and ground clearance, the rhythmic bouncing is there
Re: Mercedes W13
AA_2019 wrote:
21 May 2022, 01:29
wesley123 wrote:
21 May 2022, 01:03
AA_2019 wrote:
21 May 2022, 00:33
The bouncing is barely visible, even if you slow it down by 4x. porpoising has generally been very visible on the track cams, at regular speed.
The fact that you need to slow it down and it still is barely noticable makes it clear enough that it's not porpoising.
Spacepace
Re: Mercedes W13
Looks like there may possibly be stays bonded in the floor. You can see in the the third image the third carbon fiber slit is angled and in the fourth image a mechanic placed a helmet on top of it
Evo2racer
Re: Mercedes W13
Facts are that it’s the first time the W13 has been able to be so close to the ground & that that both drivers are happy.
Very promising and mostly due to the uprgrades brought in Barcelona!
Very promising stuff!
siskue2005
70
Re: Mercedes W13
Spacepace wrote:
21 May 2022, 03:15
https://imgur.com/gallery/YQcAbxQ
See my previous post
siskue2005 wrote:
20 May 2022, 15:23
there are interesting floor changes in that merc... are they running hidden stays like redbull?
The floor top cover has become taller, and i think there are hidden stays like this
jagunx51
185
Re: Mercedes W13
mantikos
35
Re: Mercedes W13
Spacepace wrote:
21 May 2022, 03:15
No, that's just where they mounted the sensors on the floor - go back to the launch spec car and look in that area.
