2022 Alpine F1 Team
Kamel
Kamel
Re: 2022 Alpine F1 Team
10 millions for development - hard to believe. Alpine seems to have already spent half of it. I guess next two races and packages are crucial
https://it.motorsport.com/f1/news/f1-gu ... /10302698/
UPD. Some chaps say that he's an unreliable source
Alonsismo wrote:
11 May 2022, 11:08
draghixa wrote:
11 May 2022, 08:57
diffuser wrote:
11 May 2022, 03:38
It's a fact that they have taller gears.
So for now they seem to mismatch their engine and gearbox ratio to get maximum out of the car. I highly doubt that they really made a mistake on that but instead I think they expected more power from the engine when they set this gear ratio. May be this prove that they haven't maximized the engine power somehow and we should have more to come, which is positive.
this also could explain the difference between qualy pace and race pace.
Or expected less weight and drag from the car.
Maybe this is exactly how they want it, I just don't understand why.
In Miami in Quali Alonso was
In 7th at 10.7K RPM 299KPH
in 8th at 11.7K RPM 339KPH
Which means he could probably get to 326KPH in 7th gear @ 11.7K RPM, if he had to and with Full boost of the from the MGU-K.
That's another thing we don't see in the traces. We don't see how long the MGU-K lasts and where it's being used, if not everywhere. Though it doesn't look like they're not using power where they others are. It would appear as a big difference in power.
hollus
It’s been discussed in other threads that gears matter little since 2015, there is simply enough overlap between consecutive gears to make the details unimportant.
But most important, a fact from the rules: You can change your gear ratios, once, in 2022, as an exception. So if the gears were to blame, they could change them. Which probably means that the gearing is not to blame
TANSTAAFL
hollus wrote:
11 May 2022, 23:08
I feel it's more of a final drive thing than the difference between the gears. Maybe that is the plan though, keep the RPMs below 12k on the new PU.
selvam_e2002
selvam_e2002
-1
Piastri and Doohan test Alpine F1 car in Qatar. and plan to have one in June as well. It is very interesting. . will they able to get any useful data for A522 using these test.
selvam_e2002 wrote:
14 May 2022, 08:27
Pretty sure they're test with the A521.
Where is this money for the Piastri testing coming from? I hope they are not wasting budget cap.
GoranF1
GoranF1
151
Jon Noble (Autosport) says Alpine New rear wing will be interesting.
GoranF1 wrote:
19 May 2022, 14:16
So far this weekend, it looks that Alpine seem to be preparing to run much less wing than everybody else. Which is something that they appear to doweekend in weekend out.
Wonder if we can see that thy're runing the car lower with software suspension ?
Kamel
Kamel
Again 7th gear is maximum, not expecting much from this Grand Prix
Kamel wrote:
20 May 2022, 15:18
They're hitting 8th gear on the start finish straight. I have Alonso at 317 here but he actually tops out at 318KPH. They generally shift to 8th at around 300Kph. They had the top speed in FP2. They're probably not shifting to 8th on thier long runs, when they're heavy with fuel.
SchuMassa
SchuMassa
21
Managed to make the car more than 6 tenths slower in one day.
Worst team ever!
Not sure what happened, Alonso gave up on the lap in turn 1.
