2022 - McLaren Formula 1 Team
101FlyingDutchman
101FlyingDutchman
Re: 2022 - McLaren Formula 1 Team
RIC 0.5s down after first 2 sectors then it’s 0.9s in the last sector alone
EddyBaggio
101FlyingDutchman wrote:
17 Jun 2022, 23:12
Could be trafic…
101FlyingDutchman
101FlyingDutchman
EddyBaggio wrote:
17 Jun 2022, 23:19
17 Jun 2022, 23:12
Could be trafic…
Nope. Are you watching?
Swed3120
Swed3120
-3
EddyBaggio wrote:
17 Jun 2022, 23:19
17 Jun 2022, 23:12
Could be trafic…
Considering the last sector here is almost only a long straight, I think you know what the actual cause of that deficit is
101FlyingDutchman
101FlyingDutchman
Swed3120 wrote:
17 Jun 2022, 23:22
EddyBaggio wrote:
17 Jun 2022, 23:19
17 Jun 2022, 23:12
Could be trafic…
Absolutely
CjC
CjC
Lando isn’t nailed the first lap on his fresh softs today….
Just a fan's point of view
Emag
Emag
They are indeed losing about 0.6s in the last sector. Damn shame because the first two parts of the lap are rather competitive.
Developer of F1InsightsHub
101FlyingDutchman
101FlyingDutchman
RIC 0.285 down after s2. 0.905 down on the finish line. Amazing around corners? (High df package?)
ALO 0.45 down after s2 and then claws it all back and more in s3
Emag
Emag
17 Jun 2022, 23:35
All packages are high downforce packages for this car at the moment. The drag is pretty bad.
Apparently Ricciardo's porpoising was being caused by a fault in the suspension at Baku. Ted's information
_cerber1
273
mwillems
46
Emag wrote:
17 Jun 2022, 23:44
17 Jun 2022, 23:35
At Baku they had a lower DF rear wing and a front wing that would balance with it, the drag is not related to the wings.
-Bandit
trinidefender
trinidefender
318
mwillems wrote:
18 Jun 2022, 02:04
Emag wrote:
17 Jun 2022, 23:44
17 Jun 2022, 23:35
Of course the drag is related to the wings. Bigger wings will equal more drag. Sounds like you're just referring to the balance of the car.
djos
115
17 Jun 2022, 23:21
EddyBaggio wrote:
17 Jun 2022, 23:19
17 Jun 2022, 23:12
Could be trafic…
We don’t know what fuel load etc they are running. It’s very normal for teams to run different programs on their cars across FP1 and FP2 and then use that data overnight to decide on the FP3+ setup.
Daniel was faster on every single lap of FP1, however, it means nothing overall.
Edit: and with 34 mins to go in FP2, Daniel was 2/10ths faster than Lando.
Still, the practice times are meaningless, what matters is qualifying and the race.
Edit 2: and at the end of FP2 Norris was up by 4/100ths of a second, that’s nothing. Both drivers are clearly on form this weekend.
"In downforce we trust"
EddyBaggio
17 Jun 2022, 23:21
EddyBaggio wrote:
17 Jun 2022, 23:19
17 Jun 2022, 23:12
Could be trafic…
Yes and I notised that he was close behind another car and got a yellow last sector in that lap.
