Alpine A522
Pany
Pany
Re: Alpine A522
Interesting! Assuming equal downforce in total, which one gives less drag?
Blackout wrote:
21 Jun 2022, 15:12
Small RW + big BW vs Big RW + small BW
https://pbs.twimg.com/media/FVshxirXsAE ... ame=medium
Re: Alpine A522
Pany wrote:
23 Jun 2022, 21:44
Blackout wrote:
21 Jun 2022, 15:12
My money would be on the big BW. If you look closely it looks like an extension of the diffuser. It's probably boosting the diffuser efficiency.
Re: Alpine A522
"Latios" did a nice CFD test of that beam wing design Alpine copied from RB here
viewtopic.php?p=1049768&hilit=beam#p1049768
Re: Alpine A522
There is a difference between the A522 and the other 3 ramp-shaped sidepod undercuts. The A522 front undercut is more classic and is turning air more aggressively towards the floor edge wing -a big gurney flap in the case of Alpine- (and is working with the underbody fences)
RB recently added that blister to the floor though (Spain) which seems to orientate some of the flow towards the small edge wing and that gruney-like flap (red)
So now it looks like a mix between both undercut designs
#flowviz
Nextgen-auto
Re: Alpine A522
The Alpine is also the only car with a low rear cooling outlet. The other cars raise it and shrinkwrap the bodywork around the gearbox (like here on the Toro Rosso for example)
So it seems the other teams wanted to clear that path toward the diffuser top/beam wing bottom as much as possible, whereas Alpine seems to have scarified it a bit (that path is fairly cluttered with all those suspension arms anyway) and cleared the top of the beam wing instead.
It's visible here too. It's clear how Alpine is using its "unnecessarily" wide and humpy rear bodywork to actively orientate the airflow towards specific areas, and probably to attract some of top flow downwards. #downwash
https://www.flickr.com/photos/jonmcclin ... 0299877691
Re: Alpine A522
I just came in here to tell you that somebody had these crazy good photos from Canada on flickr. Then I see you've already gobbled that up =P~
#ReleasetheADUO
continuum16
52
Re: Alpine A522
https://www.autosport.com/f1/news/ocon- ... /10328672/
According to Ocon, even more upgrades coming this week. Relentless effort from Enstone so far!
- Mark Twain
Re: Alpine A522
I think the top rear of the sidepod, yellow and orangle lines act as a venturi. I beleive that the air passing through there gets converged through the yellow section and therfore accelerates. Air passing above that squeezed section will deaccelerate in layers till it matches the speed the car is traveling at and act as a lid of the venturi. The faster the car is traveling the better the seal. The slope down in both the ridge and "valley" section have been carefully sculped to create a diverging section. At high speed this will create a suction and pull air in from the over ridge of the side pod.
I could be completely off, but I try.
Re: Alpine A522
Re: Alpine A522
AeroDynamic
349
Re: Alpine A522
new alpine side pods
Re: Alpine A522
AeroDynamic wrote:
30 Jun 2022, 15:33
https://pbs.twimg.com/media/FWgQwBPUUAc ... name=large
Holy major upgrade batman!
AeroDynamic
349
Re: Alpine A522
continuum16
52
Re: Alpine A522
diffuser wrote:
30 Jun 2022, 15:49
AeroDynamic wrote:
30 Jun 2022, 15:33
I thought they told us it was gonna be primarily focused on the floor! Would love to see another angle to see how deep the “bowl” is on the top surface.
- Mark Twain
Alonsismo
Alonsismo
Re: Alpine A522
those new sidepods look amazing.
they are like a mix of ferrari and red bull.
