Mercedes W13
16
Re: Mercedes W13
Still looks slammed; will be interesting keeping an eye on their progress this wkend.
Re: Mercedes W13
AeroDynamic wrote:
01 Jul 2022, 13:03
Looks like the rearward upper wishbone pickup point is higher and closer to the pushrod's which doesn't seem to have moved. Seems like maybe it's not purely aero in this case? Pure speculation - I don't know anything about suspension
Re: Mercedes W13
wogx wrote:
01 Jul 2022, 12:50
No info about front wing? Those rumours about 5 kg weight reduction were false?
I'd take any rumour about 5kg on a single front wing as false tbfh, it's ludicrous.
De Jokke
Re: Mercedes W13
And again an underwhelming update so far (hope the times prove me wrong), it looks like they aren't even trying to bring performance to the car. All these tiny bits, this car needs some drastic updates (starting with a complete suspension overhaul)!
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
Stu
Re: Mercedes W13
AeroDynamic wrote:
01 Jul 2022, 13:03
It looks as though the pick-up location for the rear of the upper front wishbone has changed (moved forwards and up); push-rod has changed too. Interesting move with the shrouds at the chassis end - making them more bodywork-ish; there must be some benefit, but other than a legality dodge, I’m struggling to see what it is.
adrianjordan
Re: Mercedes W13
GrizzleBoy wrote:
01 Jul 2022, 13:04
Rear wing tips on these cars are getting sharper and sharper lol.
Given that they will surely generate vortexes if they carry on like this, I wonder whether the FIA will intervene.
Favourite team: McLaren
Stu
Re: Mercedes W13
01 Jul 2022, 13:11
AeroDynamic wrote:
01 Jul 2022, 13:03
Depending on whether there are changes to the lower wishbone pick-ups (or not), I would expect this to reduce anti-dive. If the position change is large this must be a pre-planned swap. Chassis alterations of this magnitude would potentially require a fresh homologation (crash-tests, etc).
GrizzleBoy
GrizzleBoy
33
Re: Mercedes W13
All upper front suspension elemts are all now in line.
So the more forward elements will be creating a gap in the air for the rear elements and therefore reduce drag on that surface of the car.
Basically moving the rearward upper elements out of the way of oncoming air and cleaning up flow between upper and lower elements.
Edit: Upper flap of new front wing is supper skinny.
RZS10
359
Re: Mercedes W13
Hasn't extending the bodywork outwards just visually brought them together whilst the actual pickup points probably haven't changed?
Quick and ugly ...
Re: Mercedes W13
some pics from Scarbs
mantikos
mantikos
35
Re: Mercedes W13
wogx wrote:
01 Jul 2022, 12:50
You don't have to report weight reduction
Big Tea
Re: Mercedes W13
01 Jul 2022, 13:56
Is that stay in compression or tension? Which way would the floor flex? Or is it to stop 'flapping'?
Re: Mercedes W13
Big Tea wrote:
01 Jul 2022, 15:06
My initial thought was tension to prevent the floor edge bending down to strike the track, so holding it under tension should ameliorate that
chrstphrln
Re: Mercedes W13
RZS10 wrote:
01 Jul 2022, 13:40
Quick and ugly ...
https://i.imgur.com/1udzdiq.png
Thought the same.
Re: Mercedes W13
Anyone got a good shot to compare this with? Can just about see the cooling inlet here - supposedly the inlet has changed a bit
