Clutch usage while on track
hardingfv32
32
During yesterdays race the leader spun. He stated that he was nursing his clutch and that his activities caused him to spin.
I thought that the gearshifts are done without the clutch. Why would the driver need to be nursing the clutch if that is the case? What can the driver possibly do to improve the life of the clutch while on the track if it is always engaged?
I am ignoring anything to do with launches.
Brian
chrisc90
36
Re: Clutch usage while on track
Torque demand from the engine? Semi-auto's have a peak torque value for clutches. If they could 'turn it down' to limit that slip then easy enough done through the steering wheel.
Just a possibility.
617
a few years ago a Honda paper showed how F1 clutch torque transmission was varied during shifts to minimise jerkiness
by another of those servo-grade electro-hydraulic actuators - and for about 10-20 milliseconds
but at least one other poster doesn't believe this applies (currently or ever ??)
TimW
36
Last year McLaren (and others) wanted to change the clutch after sprint races, because of worries their clutch would not survive a sprint + full race distance. The issue was not so much the starts and pit stops, but the total number of gear shifts IIRC.
Which means it is active during gear shifts
Jolle
132
In the early days of paddle shifters, it’s was just a ignition advance/cut while charging gears. Now with better controls, sensors and computing power, the clutch is getting some use again in certain aspects of changing gear (mostly downshifts I presume).
Big Tea
Jolle wrote:
02 Aug 2022, 00:48
Surely it would be rev matching more than clutch slip that makes a good change out of a bad one?
Zynerji
111
Big Tea wrote:
02 Aug 2022, 00:50
Jolle wrote:
02 Aug 2022, 00:48
I'm sure it's a combination. Slipper clutches are the rave in other sports.
hardingfv32
32
We are missing something regarding the driver nursing the clutch. So far everything mentioned does sounds like a legitimate use of the clutch. These activities can all be actively control be the computer much more efficiently than any driver could. There is just no reason to expect the driver to interact with such automated activities and be able to do it more effectively.
Quite the mystery.
Brian
TimW
36
hardingfv32 wrote:
02 Aug 2022, 20:20
Quite the mystery.
Brian
I don't think he was operating the clutch. He reported clutch slip, and they told him to press 'fail 20' and some other changes. They told him it would impact drivability.
My guess a sensor issue, and the sensor bypass caused sub optimal clutch operation(but less slip).
Zynerji
111
TimW wrote:
02 Aug 2022, 20:37
hardingfv32 wrote:
02 Aug 2022, 20:20
Quite the mystery.
Brian
I would think a "failed" sensor would then resort to a derived answer by doing math on other sensor readings. Thus, becoming a psudo-assumption, and sub-optimal over a direct reading.
TimW
36
Zynerji wrote:
02 Aug 2022, 20:41
TimW wrote:
02 Aug 2022, 20:37
hardingfv32 wrote:
02 Aug 2022, 20:20
Quite the mystery.
Brian
I would love to know the details behind stuff like this. They should introduce a new rule that team-driver communications are only allowed if they are explained afterwards on f1technical!
hardingfv32
32
Interesting that an assumed negative impact on drivability did not seem to hurt his pace noticeably.
So maybe they just dialed out some of the 'shift smoothing' that was provided by the slipping the clutch. The driver was caught out by the harsher clutch application when it was used for the first time.
I wonder if someone just had the correct solution in their head, code and all, or do they use a program that lists the possible causes and solutions for a given issue is input into the program. The latest airliners are starting to do this instead of using a big manual. Time is very important in both applications.
Brian
johnny comelately
110
Regulations I didnt know existed
9.9.4 The maximum permitted duration for down changes and up changes is 300ms and 200ms respectively. The maximum permitted delay for the latter is 80ms from the time of the driver request to the original gear being disengaged.
I had the impression that the GCU reset would have just changed the position of the actuator.
Couldnt see if that was "not permitted"
the 2022 digitised version of this Image :wink:
Jolle
132
johnny comelately wrote:
02 Aug 2022, 22:29
the 2022 digitised version of this https://www.mxstore.com.au/assets/alt_1 ... %3A24%3A30 :wink:
If you think about it, quite a logical rule. A bit of delay is permitted because it's a digital signal but can't be misused to make it in practice an automatic gearbox or align gearshifts automatic with the best shift revs (or even, use it as a crude way of traction control)
saviour stivala
51
Why would the clutch on a formula one car be used during a race?. For a formula one clutch to slip when it is not being used, even for a bad clutch, the release mechanism will have to be plying a part in it.
