Ferrari F1-75
Re: Ferrari F1-75
They're functionally the same thing and one is often interchangably used with the other even in technical and research white papers.
So yes, semantics.
Your aircraft controls still get called fly-by-wire even if the thing is on the floor and you're controlling the wheel steering or brakes.
saviour stivala
saviour stivala
53
Re: Ferrari F1-75
They might be ‘interchangably used by some but not technically speaking, because it is not the correct way to speak/describe the systems used.
No technical or research paper whatever the ‘color’ will call them the same.
Yes. When an aircraft using the fly-by-wire system is on the ground or ‘floor’, the system is still called a fly-by-wire system. And when a car uses the drive-by-wire system and said car for some reason or another leaves the ground or ‘floor’, the system is still called a drive-by-wire system.
Schippke
Schippke
Re: Ferrari F1-75
*ahem*
Back to F1-75 discussion please...
Re: Ferrari F1-75
saviour stivala wrote:
03 Aug 2022, 17:50
They actually all use 'Drive-by-wire' and not 'FLY-BY-WIRE' system.
The first time I heard of fly by wire was for rocket propelled grenades that were remote controlled over a few hundred meters of cable.
saviour stivala
saviour stivala
53
Re: Ferrari F1-75
Good. Appropriate description of being operated.
aleks_ader
90
Re: Ferrari F1-75
14 Aug 2022, 08:00
03 Aug 2022, 17:50
Yeet-by-wire LOL
johnny comelately
johnny comelately
110
Re: Ferrari F1-75
Bit of info re the rear suspension design effect on hookup
Few bits if mis/dis information
In English
wuzak
wuzak
474
Re: Ferrari F1-75
14 Aug 2022, 08:00
03 Aug 2022, 17:50
Wire guided projectiles?
tnajner
tnajner
Re: Ferrari F1-75
wuzak wrote:
17 Aug 2022, 07:57
14 Aug 2022, 08:00
03 Aug 2022, 17:50
Please, start separete thred on fly by wire theories and guided projectiles, this one is abou F1-75. Thank you 😉
Re: Ferrari F1-75
wuzak wrote:
17 Aug 2022, 07:57
14 Aug 2022, 08:00
03 Aug 2022, 17:50
Yarp. Thats where the term fly by wire came from if i am correct. Then drive by wire became a thing around mid nineties with some luxury brands like Mercedes and BMW. Then brake by wire became a thing in F1.
lio007
320
Re: Ferrari F1-75
Some comparison pictures: new and old floor
by AMuS https://www.auto-motor-und-sport.de/for ... 1-technik/
In comparison RB18:
RZS10
359
Re: Ferrari F1-75
Vanja #66 wrote:
26 Jul 2022, 08:39
It's just different reflections and a curvature between vertical and horizontal surfaces. I don't think there would be any benefit of introducing a step there.
You were absolutely correct (see the middle image in the post above this one) and i became victim of those pesky pesky reflections ...hehe
f1316
f1316
84
Re: Ferrari F1-75
The new hybrid (with only a 5 place grid drop now) continues to be rumoured for Spa:
https://it.motorsport.com/f1/news/f1-fe ... /10355225/
We’ll take the it.motorsport rumours with a pinch of salt but presuming Ferrari do have a new hybrid capable of adding any performance at all to the PU (which will subsequently be frozen for 3.5 seasons), doing so in exchange for a 5 place drop at a track where you can overtake seems like a no-brainer (especially given they’ll want to avoid any penalties in Monza).
vorticism
vorticism
337
Re: Ferrari F1-75
Nicolas Carpentiers:
Re: Ferrari F1-75
Is that the area covering the fuel tank?
