2022 Mercedes-AMG | Petronas F1 Team
kenshi_blind
Re: 2022 Mercedes-AMG | Petronas F1 Team
03 Sep 2022, 18:38
Clearly I misinterpreted the data, thank you for pointing that out.
Still, looking at the data comparisons of max against other laps, you can see Verstappen braking significantly earlier for the turn where lewis makes up lots of time on him, and he gains it all back on the exit of the final corner. Pretty obvious that he's compromising his line for later gain. It's like missing the corner braking point and then taking the delta at the apex when you aren't going to make the corner. Of course you can be ahead at one particular moment but it's when the whole picture is there that reasonable conclusions can be drawn. Look at the final turn comparison for ver vs ham on his other lap and the same delta change is there. Max gives up time at T11/T12 and takes it back immediately
We are on the same page here..I was just pointing out that you miss something when you read the graph.i reckon Lewis's would have splitted the Ferrari seeing the deficit Merc has in S3 where they were loosing 2 tenths to Redbull
kenshi_blind wrote:
03 Sep 2022, 18:43
03 Sep 2022, 18:38
If Perez had finished his lap, he would have also split the Ferraris. Hard to know if it would make a difference.
Beware of T-Rex
kenshi_blind
03 Sep 2022, 19:10
kenshi_blind wrote:
03 Sep 2022, 18:43
03 Sep 2022, 18:38
Lewis was up on Perez's time as well and so was George, my point was Lewis had a chance of front row as he alluded to himself after qualy.Looking at the telemetry, the same cannot be said for Perez
chrisc90
Lewis was NEVER getting onto the front row.
Where he would have found .110 to even match Charles after being .134 down in the middle sector is anyones guess.
chrisc90 wrote:
03 Sep 2022, 19:23
Well, sorry to report but HAM did just that. Whatever deficit there was at the end of sector 2, he turned into a lead by the end of T12.
2 corners of magic, 11 & 12 - purple mini sector.
Yup. He was saving tyres for the final sector. Data wont tell you that.
101FlyingDutchman
101FlyingDutchman
03 Sep 2022, 20:42
You also can’t POSSIBLY know this
chrisc90
214270 wrote:
03 Sep 2022, 20:27
chrisc90 wrote:
03 Sep 2022, 19:23
The results told a different story. The most draggy car on the straight which had the slowest speed trap amazingly beating 2 different cars on a flat out piece of track. One mini purple sector doesn’t mean anything when you consider there’s another handful to go before the finish line.
napoleon1981
napoleon1981
03 Sep 2022, 20:42
Lmao, yeah and he had a whole battery to dump too in the final sector....
chrisc90 wrote:
03 Sep 2022, 21:19
214270 wrote:
03 Sep 2022, 20:27
chrisc90 wrote:
03 Sep 2022, 19:23
Top speeds between LEC & HAM are pretty similar and LEC ended up fractions off all told, being slightly behind after 12. HAM who was further forward could’ve done the job. It would’ve been a challenge but doable, VER lost time through 13.
Cs98
Cs98
214270 wrote:
03 Sep 2022, 21:40
chrisc90 wrote:
03 Sep 2022, 21:19
214270 wrote:
03 Sep 2022, 20:27
But not speeds off the last corner. The Merc seemed terribly slow coming off the last corner in all the telemetry. Look at Lewis’ first lap compared to Max’s pole lap. He loses 3 tenths from the exit of the last corner to the finish.
They clearly put on more downforce, so keeping up in the twisty section was a given.
napoleon1981
napoleon1981
chrisc90 wrote:
03 Sep 2022, 21:19
214270 wrote:
03 Sep 2022, 20:27
chrisc90 wrote:
03 Sep 2022, 19:23
How accurate are mini sectors? Is that taken off a GPS signal, or do all tracks have multiple loops throughout the course? If it is the former (GPS), these mini sectors are probably not too acurate.
chrisc90
napoleon1981 wrote:
03 Sep 2022, 22:54
chrisc90 wrote:
03 Sep 2022, 21:19
214270 wrote:
03 Sep 2022, 20:27
Not too sure. Be interesting to know how they set the track up in that respect. I imagine it will be GPS.
El_KaPpa
El_KaPpa
Re: 2022 - McLaren Formula 1 Team
An interesting quote from G Russell: "We understand why we were slow in Spa and why we are faster this weekend, so I think these two races have been key to our understanding of how to make a faster car across 23 races.”
Of course I struggle. I just don’t quit.
El_KaPpa
El_KaPpa
Interesting quote from G. Russell: "We understand why we were slow in Spa and why we are faster this weekend, so I think these two races have been key to our understanding of how to make a faster car across 23 races.”
