vorticism wrote: ↑11 Sep 2022, 14:21
RZS10 wrote: ↑11 Sep 2022, 14:09
The answer to "why was Leclerc's lap in Q1 not deleted?" is probably that the white line in that particular corner is just ... fat
https://i.imgur.com/aWTBbn2.png
The image is from Q3
https://i.imgur.com/IcpOryx.png
This is Sainz just ahead of LEC in Q1
https://i.imgur.com/QBZZrOp.png
This is parabolica, wider white line once the curb starts.
The low quality screenshot obviously hides this, but from every camera angle it's visible that there is no way to distinguish between the white line and the trackside white of the curb, which leads me to believe that the line there is everything up to the red/green - meaning he was very very likely still on the line.
Could you not argue that there is also a white line on the outside of the curb
Of course, but common sense kinda says that the white line is on the very edge of the track - on some tracks like Spa the curbs have no white at all so it's easy, but on every track with white/red/x curbs the line between those alternating colours and all white is where the edge of the line is defined, i'm relatively sure that the line they painted there is slimmer, that can be seen at the exit of T10/ Variante Ascari for example:
There is a clearly visible distinction between curb and line - what they used to judge off tracks is anyone's guess.
Elsewhere there is no extra white on the inside of the curb
But they have no way to enforce anything if there is no visible difference between the all white inside part of the curb and the line, that is the limit of the purely visual system they use, trying to guess what is and what isn't on the line anymore would lead to completely arbitrary decisions.
That the best camera to judge it produced such images towards the end of the session also did not help
