Mercedes W13
101FlyingDutchman
101FlyingDutchman
Re: Mercedes W13
Just_a_fan wrote:
15 Sep 2022, 17:28
The top lip of the diffuser on the W13 is basically flat i.e. no up turn. The lip on the RB18 appears to have a large up turn which must surely interact with the beam wing more effectively. Is this an example of Red Bull sacrificing diffuser volume for better overall effectiveness? They were masters of it in the previous rule set and others followed them. I wonder if Mercedes will do something similar next season.
Perhaps it's another little piece in the non-porpoising design that Red Bull managed to produce this year.
Especially after TD39 the car seems perfectly balanced. It doesn’t need to produce more peak downforce. As a total guess it produces say 98% of the downforce the Ferrari generates however it does it for a far lesser drag penalty and seems stable through a large ride height setup window without massively tailing off
Zynerji
112
Re: Mercedes W13
I legitimately do not think the problem is Aero at Mercedes. I think they got hammered by the loss of the hydraulic platform control of the previous seasons. If all of your recent suspension design R&D folders are filled with compromised designs that the hydraulic system mitigated, your last real experience would be 2013, and that's years behind others in data.
It's all about the contact patch control at Merc.
georgekyr
georgekyr
Re: Mercedes W13
Zynerji wrote:
15 Sep 2022, 17:33
While I agree with you about the suspension being the biggest challenge of W13, Merc abandoned the hydraulic system 2 seasons back and migrated to a mechanical one to be prepared. But there was a big number of innovations that were outlawed in the new set of regulations most of which were developed by Merc. The below article in essence was spot on. Merc did not manage for me to surpass all the challenges mentioned in it concerning W13's suspension.
https://www.formula1.com/en/latest/arti ... 4bp8j.html
Zynerji
112
Re: Mercedes W13
georgekyr wrote:
15 Sep 2022, 20:47
Zynerji wrote:
15 Sep 2022, 17:33
Merc just switched their heave springs to mechanical. I believe the corners were still hydraulic.
Watch any 2021 race with a chicane. They almost float over them...🙃
Re: Mercedes W13
Zynerji wrote:
15 Sep 2022, 17:33
It is aero. The car has to run a lower ride than competitors to be fast.
mantikos
mantikos
35
Re: Mercedes W13
Zynerji wrote:
15 Sep 2022, 17:33
This is my guestimate as well - they screwed up suspension since they were amongst the most advanced in hydraulics and that got nixed
Zynerji
112
Re: Mercedes W13
15 Sep 2022, 21:03
Zynerji wrote:
15 Sep 2022, 17:33
I disagree. But that is the best part of these forums! We can speculate. And I put tyre temp control as the main issue, and that's suspension control for sure.
Re: Mercedes W13
Zynerji wrote:
16 Sep 2022, 01:01
15 Sep 2022, 21:03
Zynerji wrote:
15 Sep 2022, 17:33
The engineers set up the car for when the tyres are warm though so what you are seeing in the race is the best of the car. Tyre heat won't solve the deficit.
Zynerji
112
Re: Mercedes W13
16 Sep 2022, 01:40
Zynerji wrote:
16 Sep 2022, 01:01
15 Sep 2022, 21:03
I never said tyre heat, I said temperature control. The kinematics of the suspension and the reactive forces through all modes generate different wavelets that determine the interface of the tyre and the circuit. This harmonic is solely controlled by the suspension, and is responsible for the temperature of the tyre at any given phase of operation.
Re: Mercedes W13
That's overthinking it though. The aero just sucks. And not in a good way!
Re: Mercedes W13
https://www.auto-motor-und-sport.de/for ... -singapur/
Small updates for the end of the season
Seems the W13 will not remain unchanged according to AMuS. Will be interesting to see if they can handle the bumps at singapore - surely all the learning about the car will pay off at some point
For the last races of the season, Mercedes will continue to equip the Silver Arrow with new parts. Albeit on a small scale. "The greater advances come from understanding," the team continues. In the remainder of the program there doesn't seem to be a track that should throw the Mercedes completely out of step. "Maybe Austin suits us just fine," Russell looks ahead
clownfish
Re: Mercedes W13
Can anyone offer any thoughts on the car's tyre behaviours in terms of difficulty getting temperature in/having low deg?
I wondered if maybe they are running higher pressures in an attempt to eliminate the undamped spring effect from the tyres to help control porpoising, and therefore putting less heat in as a side effect.
marcel171281
marcel171281
31
Re: Mercedes W13
clownfish wrote:
16 Sep 2022, 14:07
I don't believe they have difficulty to get temp in the tyres, otherwise they wouldn't get the hard tyres to work so easily in Zandvoort for instance. From the outlap on they were quick in that stint.
There are two forms of deg. Wear, the most obvious, but also thermal deg. The latter is the change in chemical composition of the rubber due too long or over exposure to (too) high temps. I believe the Mercedes is very good at the latter, which means they are good in controlling tyre core temps on long stints.
Getting temp in the tyres initially and keeping the core temps under control are not necessarily connected as one has mostly to do with surface temps and the other with core temps.
This also indicated that the suspension of the Mercedes is not the issue this year. On the contrary, I believe it is their strongest point.
Re: Mercedes W13
marcel171281 wrote:
16 Sep 2022, 14:24
clownfish wrote:
16 Sep 2022, 14:07
I don't believe they have difficulty to get temp in the tyres, otherwise they wouldn't get the hard tyres to work so easily in Zandvoort for instance. Form the outlap on they were quick in that stint.
Getting temp in the tyres initially and keeping the peak temps under control are not necessarily connected as one has mostly to do with surface temps and the other with core temps.
Zandvoort is an outlier to be honest. It has extremely high load on the tyres due to the banking and other cars that usually struggle to make the tyres work in qualifying could also get enough temperature eg AMR. Merc have had a tyre temperature issue for a long time. Not just all of 2022 bar Hungary and Zandvoort, but in 2021 as well. It's something fundamental to their philosophy I am supposing
Re: Mercedes W13
16 Sep 2022, 14:24
marcel171281 wrote:
16 Sep 2022, 14:24
clownfish wrote:
16 Sep 2022, 14:07
Zandvoort is an outlier to be honest. It has extremely high load on the tyres due to the banking. Merc have had a tyre temperature issue for a long time. Not just all of 2022 bar Hungary and Zandvoort, but in 2021 as well. It's something fundamental to their philosophy I am supposing
It goes back even further. That's why they had devices like the rim heating and DAS.
#ReleasetheADUO
