johnny comelately wrote: ↑Tue Sep 27, 2022 6:55 am
gruntguru wrote: ↑Tue Sep 27, 2022 4:56 am
For the PU as a whole. This rule does in fact limit how quickly the torque drops off after torque peak. (The throttle position determines the rpm where torque peaks).
5.6.4 At any given accelerator pedal position and above 4,000rpm, the driver torque demand map must not have a gradient of less than – (minus) 0.045Nm/rpm.
"There is a rule crying out to be validated" said the progressives :wink:
broadly this seems to be as close to constant power as the ICE run beyond 10500 with capped fuel rate can be
(presumably FIA checks from torque sensor data have always showed compliance)
and as close to constant torque below 10500 as will fit the fuel rate regime that deters slower running
the gradient specified would have greater effect given the lower maximum power of the new ICE
unless we read the words as meaning the opposite ie the torque below 10500 could fall fast ...
eg as in NA days when there was unregulated mapping - did drivers to some extent drive 'on the limiter' ?
and with fuel energy eg c.70% of the present amount ....
ICE energy will fall to eg c.63% of the present amount (as with no H for recovery the new ICE efficiency will be less)
