Oddball question for the resident garagistas.
Zynerji
112
A friend of mine is in process of building a 36x36x84 inch core x/y style 3d printer with the sole intention or making large car parts. We were chatting about the possibility of pulling a single-seater chassis out of a printer that large in a single carbon-fiber nylon (or whatever) print.
Then the discussion got interesting. Apparently GM built a hybrid transmission with an integrated 160hp electric motor. The thought then came up about just bolting that trans off the tail of a printed chassis, and just hanging batteries on the side, along the floor.
I know it was just a tongue-in-cheek joke at the time, but it's been in my head all day.
Any thoughts from the engineers here about this idea?
https://www.transmissiondigest.com/gms- ... mission-2/
Billzilla
Billzilla
Re: Oddball question for the resident garagistas.
A plastic filament printer is never ever going to be able to print a strong enough chassis. Well, maybe for an RC car but certainly not a full-sized one.
Best off looking at the metal 3D printing systems that SpaceX have, they work very well on printing various parts for rocket engines.
Zynerji
112
Billzilla wrote:
13 Oct 2022, 23:35
I'm not worried about the chassis! I'm asking about this transmission!
I can weld up some pipes to mount it to. The question is how reasonable it would be to run it as an EV driveline. Mounting to a well printed, acetone smoothed, bed liner sprayed monolithic tub is rather inconsequential to the point. 😁
Any speculation about the transmission?
Stu
If I was going to do this I would use the FWD version, but mount it longitudinally providing 4WD and two axle regeneration. With the ‘right’ battery packaging you could end up with a very compact Auto-solo/Sprint-Hillclimb car (depending on whether you are UK or US based). The bell-housing is tailor-made for direct mounting to a bulkhead.
Zynerji
112
Stu wrote:
14 Oct 2022, 07:53
Good call. I kind of didn't even dig into the mountings on the FWD one. I was more interested in if the RWD one would hold up as a stresses member.🤣
The FWD used as AWD is a killer idea! Thanks😁
Billzilla wrote:
13 Oct 2022, 23:35
Off topic here but ironically a massive amount of research has gone into printing rocket parts with those little plastic filament printers and they work surprisingly well, even for motor nozzles. :wink:
