Red Bull RB5 aero-mech development in 2009
bar555
bar555
FRONT WING - JEREZ FEBRUARY TESTING
FRONT WING - AUSTRALIA
The RB5 is one of the most innovative and radical cars of 2009. The chassis is V-shaped (1) on top, improving the management of airflow towards the rear of the car. Both the chassis and suspension are higher than on the previous RB4, as is the position of the driver's feet. The two central pillars (2) connecting the nose to the front wing are straight and close together, while the wing's main plane is intricately shaped where it joins the endplate (3) to direct airflow under the wing. Both the main plane and the upper flap are slotted (4). Also note the ballast compartment (5) in the endplate.
Source : www.f1.com
FRONT WING - MALAYSIA
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
bar555
Re: Red Bull RB5 aero-mech development in 2009
REAR WING - JEREZ FEBRUARY TESTING
REAR WING - AUSTRALIA
The shark fin is connected directly to the rear wing
REAR WING - MALAYSIA
bar555
bar555
FRONT SUSPENSION - KEEL
The RB5 is almost certainly the most innovative and extreme car on the 2009 grid. Its chassis is very high at the front, with its unique U-shape meaning the front suspension's lower wishbones share almost a single pickup point, with just a small separation in between (red arrow). This solution has the benefit of allowing a large volume of air to pass under the chassis and feed the (conventional) rear diffuser.
Source : www.f1.com
1.Upper wishbone
2.Lower wishbone
3.Pushrod
4.Ride height sensor
5.Nose to Front wing connection
6.Steering arm
bar555
bar555
REAR SUSPENSION
The RB5 brings pull-rod rear suspension back to Formula One for the first time in over 20 years. With the diffuser moving rearwards under the revised 2009 regulations, the pull-rod layout (2) - where the suspension rockers are pulled rather than pushed by the rod - allows for cleaner aero packaging (see inset for more common push-rod set-up). The pull-rod suspension is lighter and, along with a gearbox that is now 15cm lower, helps to lower the car's centre of gravity and improve handling. The top wishbone is a single piece and is attached very high at the rear of the car (1), forming a wing-like section that works together with the lower section of the rear wing. Also note the very low and rearward positioning of the exhausts (3), which exit just under the front arm of the rear wishbone, and the lack of a central pillar to the rear wing, which is instead mounted via the wing's two large endplates, which attach directly to the diffuser.
source : www.f1.com
ENGINE COVER - AUSTRALIA
FRONT WHEEL RIM SHIELDS - AUSTRALIA
Different fairings for Australia
FRONT BRAKES - AUSTRALIA
FLOOR
bar555
bar555
NOSE CONE
BARGEBOARDS
REAR LIGHT
bar555
bar555
DIFFUSER
Extended rear wing’s endplates which meet the diffuser.
FRONT BRAKES - MALAYSIA
GTO
A+ for bar555 towarads this great work in posts.
B for Adrian Newey, Geoff Willis team for designing a beautiful car, that has moved up the grid considerably from 7th overall last year to currently 2nd. However, it is not yet capable of matching the pace of Brawn. I believe, most of that shortfall is with the Renault engine and the RB5 chassis on its own is capable of winning races if it had a stronger engine.
tadzio89
tadzio89
Why do you think that Renault engine is not good enough?
too less power, a not very well reliability
bar555
bar555
REAR FOOTLATE HOLE
Introduced in Malaysia and retained for China is this hole in the floor's footplate in front of the rear tyres. Its purpose is to create a vortex that improves the quality of the airflow directed into the side channels of the rear diffuser, thus boosting downforce.(From http://www.f1.com)
STEERING WHEEL
Dragonfly
Dragonfly
A shot from Monaco (Vettel's car) with, what I believe, the latest modifications on the floor and ducts to feed the DD. Also the conventional diffuser is well seen.
Spa 2012
NormalChris
NormalChris
Awesome pic!
BreezyRacer
BreezyRacer
Great great shots! That RB5 is sooo sweet! Have you noticed the filup/diffusers that were added to the sides of the floor along the sidepod area a few races a go? I would like to see more about those .. I'm surprised no one has talked them up. It looks to be a sweet detail.
bar555
bar555
FRONT BRAKES - CHINA
REAR BRAKES - CHINA
FRONT BRAKES - BAHRAIN
DM0407
DM0407
I remember a few weeks back everyone was talking about how the Brawn cars have their calipers mounted below the rotor. Now it seems like every team is doing it.
Now all the teams have the brakes this way... Did it really take the Brawn's doing this for the other teams to realize it? Seems like a pretty straight forward issue.
