TD039
Re: TD039
carisi2k wrote:
06 Sep 2022, 08:20
05 Sep 2022, 20:27
TD039 introduced the AOM metric.
No TD039 was about the plank flexing 6mm and the measurements holes and not the measurement of aerodynamic oscillation which is a different TD.
It was all pushed through under the same TD, TD039
vorticism
vorticism
449
Re: TD039
Does anyone have a copy of TD039?
If I was going to flex the floor I might start with the firewall. What's to prevent a team from making a rear chassis face (the rearmost fuel cell wall) which can flex? The floor test would not show anything since they only span either side of this mounting face. To test for it you need to apply a force above the firewall f.e. through the roll hoop and measure any bowing of the chassis.
For the Ferrari which might have its COP more near the middle as Vanja pointed out in another thread we would have the low pressure region of the floor acting as the downward force which could bend the engine into the firewall. Depending on suspension geometry and rake this then could provde some extra ground clearance either fore or aft of the deflection center.
Conversely, if the front and rear wings, being beyond wheel centerline, could provide enough force to bend the weak point in the center of a chassis, the floor could then bend up instead of down, which when combined with slight rake might help ensure the middle of the plank doesn't touch the ground.
caddy
caddy
Re: TD039
As none of the online articles are clearly spelling out what TD039 is, I thought of posting this here too, as I posted in FIA thread.
Most online articles are mixing up TD039 with porpoising metrics and saying that, TD039 is issued to stop porpoising, which is incorrect. FIA had suspicion that some teams are exploiting the plank stiffness grey area and issued the TD to address it. Here is the link to the document and the relevant update.
https://www.fia.com/sites/default/files ... -08-16.pdf
Convention:
Black text: All text from previous versions of the regulations
Pink text: Changes approved by the WMSC on 16 August 2022
3.15.8 Central Floor Flexibility
a. Bodywork within RV-PLANK may deflect no more than 2mm at the two holes in the
plank at XF=1080 and no more than 2mm at the rearmost hole, when the car, without
driver, is supported at these positions. The car will be supported on 70mm diameter
pads, centred on the holes, and only in contact with the underside of the plank
assembly. The displacement will be measured at the supports, relative to the
reference plane at the centre of each hole.
Furthermore, the stiffness for any load exceeding that defined in the previous
paragraph must be no less than 15kN/mm.
Competitors will be required to demonstrate the local vertical stiffness and design
installation of the skids and plank to the FIA for the regions around the periphery of
each of these three holes. Compliance with Article 3.5.9.e. will only be assessed in the
regions that are at least 90% as stiff as the stiffest part of the periphery. Any designs
intended to protect these regions of the periphery from wear will not be accepted.
Competitors will be required to demonstrate compliance with these provisions by way
of a detailed inspection of both the CAD and the physical installation, as well as Finite
Element analysis.
My guess as to why they call it TD039 is that, Plank Reference Volume is listed as 39th Reference Volume in the Technical Regulations and hence, TD039 is a technical directive that clarifies the Reference Volume 39, which is Plank Reference Volume (RV-PLANK).
JordanMugen
90
Re: TD039
vorticism wrote:
09 Sep 2022, 21:10
That's what the engine and gearbox (i.e., the rear end of the car) is attached to. Why would you want to make your whole car floppy, wouldn't that make it handle horribly? :wtf:
graham.reeds
graham.reeds
16
Re: TD039
It could make it bounce up and down...
Seriously though, if you can design a front wing to flex enough that it dramatically sheds downforce but strong enough that it passes the FIA tests then you can probably design a chassis that has a little flex to allow the bottom to reach lower to the floor.
marcel171281
marcel171281
31
Re: TD039
graham.reeds wrote:
29 Nov 2022, 03:24
Have you ever driven an old Saab convertible?
The front wing isn't a structural part of the car. The tub however is the most important structural part of the lot. You want an absulute minimum of any form of deformation in that part as it will effect every other element of the entire car, both in terms of geometry and aero.
BTW the wing isn't part of the FIA crashtest, the nose cone is. Nose cones don't flex.
graham.reeds
graham.reeds
16
Re: TD039
marcel171281 wrote:
29 Nov 2022, 14:22
graham.reeds wrote:
29 Nov 2022, 03:24
I never said crash test. The FIA does loading tests with weights on the wings to measure deflection. That was the test I was referring to.
marcel171281
marcel171281
31
Re: TD039
graham.reeds wrote:
01 Dec 2022, 08:40
marcel171281 wrote:
29 Nov 2022, 14:22
graham.reeds wrote:
29 Nov 2022, 03:24
I misread (minor form of dyslexia here).
But still, flexing wings or not, flexing chassis? Too unpredictable in too many area's. Imagine doing calculations and designing a suspension where the pickup points of are not a stable factor, because the main thing they're connected to starts moving around depending on loads and speeds. As the floor is a seperate piece only bolted to the rest of the car when everything is already in place, it is much simpler to get the desired effect by making the floor itself flexing relative to the tub.
Re: TD039
https://www.racefans.net/2022/12/29/fia ... u-symonds/
“In Baku we saw the worst impact because a team tried something that didn’t work and then went public quite loudly.
“Had they not intervened, the problem would have been solved. Most teams now understand how to control bouncing.”
You don't say, FIA bending to the will of Mercedes? No way! :lol:
I love the irony of this intervention backfiring and sealing MV title and all the maxxed-out records
jordanb
jordanb
Re: TD039
Vanja #66 wrote:
30 Dec 2022, 00:09
They did that second year in a row. In 2021, Pirelli changed tyres, again due to what happened in Baku. They cited safety as the issue and changed the tyres that, reportedly, benefitted Mercedes when the new compounds were introduced.
Asthe season progressed teams such as Mercedes increasingly mastered their porpoising problems. However it remained a factor at some circuits, including Yas Marina, scene of the season finale.
This happened as FIA junked Porpoising metrics from Singapore GP.
chrisc90
Re: TD039
jordanb wrote:
30 Dec 2022, 05:13
Was the porpoising metric in use at Yas Marina?
I should hope it was given that it was brought in as a safety factor to protect the drivers. If they can pick and chose what tracks to have it enforced at, its a totally pointless system to have in place.
Its almost a bit like being able to chose whether to wear your helmet, race gloves, seatbelts. If something is implemented to protect a driver, then it should be used and enforced on each occasion the car leaves the pit garage.
Re: TD039
In hindsight it all looks a bit silly. The rules were changed because a team was rumored to have a '23 car with enough downforce to pull up the track surface. :wink:
Beware of T-Rex
vorticism
vorticism
449
Re: TD039
30 Dec 2022, 22:43
Who? Someone had a super skate or some other ground contact feature?
Re: TD039
vorticism wrote:
19 Mar 2023, 00:19
30 Dec 2022, 22:43
No, I mean a very powerful vacuum cleaner :lol:
Beware of T-Rex
ScrewCaptain27
577
Re: TD039
According to Italian Motorsport.com, it has been abolished as the 2023 regulations changes made it redundant.
https://it.motorsport.com/f1/news/f1-ce ... /10448664/
- Serj Tankian
