2023 pecking order predictions
skoop
skoop
Re: 2023 pecking order predictions
Bill wrote:
03 Jan 2023, 10:25
jordanb wrote:
03 Jan 2023, 03:40
THIS IS 2023 PECKING ORDER PREDICTION THREAD!
it does not specify the pecking order of what real ,drivers ,cars ,or anything for that matter
Seems like a lawyer entered the conversation :D
jordanb
jordanb
Bill wrote:
03 Jan 2023, 10:25
jordanb wrote:
03 Jan 2023, 03:40
Correct. What exactly is George's red flag in Brazil qualifying and the events around it add to the "2023 Pecking Order" topic?
Bill
Bill
jordanb wrote:
03 Jan 2023, 15:30
Bill wrote:
03 Jan 2023, 10:25
jordanb wrote:
03 Jan 2023, 03:40
you need to read back people where talking about rivalry in 2023 using 2022 as reference point ,implying that it will continue that how last year was bought in conversation.
Stu
It does, however, specify that it is for the 2023 season; therefore anything previous to that is historical (not a prediction) and pre-2023. This makes it off-topic…
Sisyphus_1
TimW wrote:
01 Jan 2023, 22:07
Sisyphus_1 wrote:
31 Dec 2022, 23:46
Lots of faith in Mercedes from many posters.
...If they do it they deserve to be crowned kings of the milkyway galaxy, but it's doubtful.
I'm going to go with:
1. RB
2. SF
3. MB
4.Alpine
5. AM
6. Mclaren
Yet you have faith in AM to overcome as much (or more) of a deficit to McLaren
In the end the RB performance is the result of the first year of development. I don't see how Mercedes with their very strong team, sufficient pictures of the RB with all details to analyze and a second year of development with a wind tunnel time advantage would not be able to catch up. Not saying they will, but they definitely could (should?).
Given their history it is an easy argument to make in their favour....buuuuuut....they got these years regs wrong (by their standards) which means they are in a knowledge deficit to RB and SF.
As RB and SF had great packages from race 1, they only need to refine.
Big Tea
Sisyphus_1 wrote:
04 Jan 2023, 20:52
TimW wrote:
01 Jan 2023, 22:07
Sisyphus_1 wrote:
31 Dec 2022, 23:46
1. RB
2. SF
3. MB
4.Alpine
5. AM
6. Mclaren
Alternately, if RBR got their package right 'straight out of the box' there is not going to be as much easy pickings as one that missed by a mile. Providing of course they know where the problem lies.
It is possible they still do not have a handle on 'the problem' because it did seem to vary from race to race.
TimW wrote:
01 Jan 2023, 22:07
Sisyphus_1 wrote:
31 Dec 2022, 23:46
1. RB
2. SF
3. MB
4.Alpine
5. AM
6. Mclaren
The slower teams have much lower hanging fruit than the bigger teams.
AM may well leap into the head of the midfield but breaking the top 3 won't be as simple. That's where you start to need the best of the best in terms of engineers and resources.
It's no wonder why teams like Alfa Romeo, AM, alpine, Mclaren, Williams bounce around in the rankings of the midfield, but they never actually breach the top 3. The former is much easier than the latter.
The technical regs can go one of two ways.
The raised floor ruling can snip RedBull's advantage of using higher rake coupled with articulate suspension and awesome vortex sealing....
Or...
It could pay even more dividends for RedBull's mastery of sealing higher ride-height floors!!
The pecking order is a very tough call this year.
I'm getting a sense that McLaren will finally fight in the top ranks for some reason..
chrisc90
22 Jan 2023, 23:58
Or...
Would running higher initially not lessen the effects of the 2023 rule changes? If the floor is raised higher at the rear, then the RB was already running with rake and pretty high at the rear compared to others.
chrisc90 wrote:
23 Jan 2023, 00:06
22 Jan 2023, 23:58
Or...
There is no doubt that running the car closer to the ground generates more DF. No team ran higher ride height in 2022 to increase DF. It was usually done to prevent the car or drivers from disintegrating from the porpoising. When they were running flat out in a corner, all the cars were as close to the ground as possible with little to no rake.
chrisc90
diffuser wrote:
23 Jan 2023, 00:37
chrisc90 wrote:
23 Jan 2023, 00:06
22 Jan 2023, 23:58
Or...
What about the static ride height though? Where the measurements for parc ferme are taken? Surely if you can have a higher static ride height to pass the tests, but your car then runs close to the ground when driven then surely its an advantage?
chrisc90 wrote:
23 Jan 2023, 00:40
diffuser wrote:
23 Jan 2023, 00:37
chrisc90 wrote:
23 Jan 2023, 00:06
From what I understand, how far down the outer floor edge can come down is measured from the plank. Whatever the height that the floor edge had to be above the plank in 2022, they added 15mm for 2023. So if you want to get closer to the ground, you need pull up the plank.
Chuckjr
37
Maybe someone here can help me understand why since the new regs require a rear lift the Merc supposedly is advantaged when Merc have said repeatedly they need their car planted on the ground to get the most out of their concept. Why is Merc the most advantaged when RB in fact runs a high static height already? All cars are basically on the ground in the corners.
Honest question.
Watching F1 since 1986.
mendis
mendis
19
Chuckjr wrote:
23 Jan 2023, 21:10
Honest question.
To avoid porpoising, Mercedes has to run higher. While the best performance of their car is running lower, but then it starts it's disco at that state. So by having forced these regulations, other teams also now have raised floor edges and diffuser opening now, by which they lose downforce and potentially go on par with Mercedes, who anyway have to raise to keep sanity of the car and drivers.
Chuckjr wrote:
23 Jan 2023, 21:10
Honest question.
During the season this a bigger issue to overcome but they seemed to have gotten car under control by the end of the year. So those learnings were fed into the new car design. It all comes down to what the find in the wind tunnel.
