Mercedes W14
Venturiation
Venturiation
103
Re: Mercedes W14
Mchamilton wrote:
15 Feb 2023, 18:39
Venturiation wrote:
15 Feb 2023, 18:20
if he followed more the green petronas line you have approximatevly the same line in W13
https://pbs.twimg.com/media/FpAlJ8MXgAA ... name=large
The lines are meant to follow the contours of the bodywork not the livery lol
i know but if he followed the rear it's the same shape
Venturiation
Venturiation
103
Re: Mercedes W14
15 Feb 2023, 18:39
Venturiation wrote:
15 Feb 2023, 18:20
Those lines look nothing alike in my view
on the W13 dont stop drawing so soon, keep going to the rear until below the R of petronas and you see that the shape is very similar
Re: Mercedes W14
Much longer sidepods than launch spec W13 and much wider than zeropods. Those are history indeed.
Vanja #66 wrote:
15 Feb 2023, 14:48
Also I'm really not a fan of clogging the rear wing airflow with such a bulky engine cover, but that's just me. W14 solution with gutters in that zone looks well worked out and better than any other team going that way (unless RB19 has something similar).
I was wrong here, AMR23 has those same engine cover gutters.
michl420
michl420
Re: Mercedes W14
They focus on less louvres and more hot air to the rear exit, like almost everyone. From a technical point it is an interesting car for me. From an estetic it is ugly.
Goblin42
57
Re: Mercedes W14
Cassius wrote:
15 Feb 2023, 18:38
Barely any paint. My assumption is they weren't able to hit the minimum weight without abandoning their silver paint scheme.
Sometimes it's not enough to hit the minimum weight, the teams would like to play with ballast to change the weight distribution for the car here's an example from last year's Alphatuari front wing
clownfish
Re: Mercedes W14
pursue_one's wrote:
15 Feb 2023, 18:08
Venturiation wrote:
15 Feb 2023, 17:59
pursue_one's wrote:
15 Feb 2023, 17:29
Apparently Mercedes’ shakedown did not go according to plan.
could the rumored more hp causing this?
It was a mounting issue which caused ignition problems.
Is this a trust worthy account?
Re: Mercedes W14
Mchamilton wrote:
15 Feb 2023, 18:39
Venturiation wrote:
15 Feb 2023, 18:20
SIPS is included in one and omitted in the other. If you remove SIPS from the sketch of the W13 it’s the same shape lower. The repackaging is fooling a lot of people
Re: Mercedes W14
Venturiation wrote:
15 Feb 2023, 18:45
15 Feb 2023, 18:39
Venturiation wrote:
15 Feb 2023, 18:20
They look nothing alike. One is convex aft of the driver. The other is concave aft of the driver.
#ReleasetheADUO
edgelo
edgelo
Re: Mercedes W14
Vanja #66 wrote:
15 Feb 2023, 18:46
Vanja #66 wrote:
15 Feb 2023, 14:48
To my knowledge makes more sense the rear end cannon in the case of the AMR23 (and Alfa and almost all the rest but Ferrari) because they want to push the flow to the ramps and direct it over the diffuser and the beam wing.
But in the case of W14 I would expect them to leave the stream go free over the cover engine down. I don’t get where they mainly intend to bring the air to feed the diffuser in an orderly manner.
Am I entirely wrong?
edgelo
edgelo
Re: Mercedes W14
clownfish wrote:
15 Feb 2023, 18:48
pursue_one's wrote:
15 Feb 2023, 18:08
Venturiation wrote:
15 Feb 2023, 17:59
No, it’s not
He might know a couple of people, but he sure wouldn't be the first to know.
johnny comelately
johnny comelately
110
Re: Mercedes W14
Has this been posted yet? (from B Sport), if so i will delete
Venturiation
Venturiation
103
Re: Mercedes W14
something fell from the car
NoDivergence
NoDivergence
52
Re: Mercedes W14
Venturiation wrote:
15 Feb 2023, 19:47
That's not from the car
Re: Mercedes W14
edgelo wrote:
15 Feb 2023, 19:39
All teams bar Ferrari and Haas chose more centerline cooling, so it makes sense they need taller engine covers. While they are there, they simply extend the bodywork and make the wide outlet in a low pressure zone under the rear wing. It's not a bad design at all in that regard, I just prefer what Ferrari and Haas do. In my view, maximising rear wing performance is key to keep the drag down.
chrstphrln
Re: Mercedes W14
Toto says yes, the sidepods are the first iteration and it is already planned to have revised them after a few races.
For me, that means that it was noticed too late that the revised concept simply doesn't have the potential that Mercedes had hoped for for a long time.
Even if Toto downplays the influence of the sidepods, the interview sounds very much like a farewell to their current sidepod concept.
https://www.motorsport-total.com/formel ... n-23021511
