Mercedes W14
Re: Mercedes W14
Some turning vanes around (possibly a part of) the floor edge wing which obviously skirt legality. I assume they are telling fia that these are their attachment brackets, similar to their argument for their mexico front wing slot gap separators. Might get complained about to be honest
sbrillo
sbrillo
Re: Mercedes W14
16 Feb 2023, 14:26
https://i.imgur.com/2hXjW3n.jpeg
grey area perhaps?
Re: Mercedes W14
Just spotted that also after brightening the image. Presumably for structural support? Can't imagine it has a huge aero benefit. Might be a compromise from slimming down the mid-wing so much
Goblin42
57
Re: Mercedes W14
Venturiation wrote:
16 Feb 2023, 14:10
what are those teeth below the floor?
https://pbs.twimg.com/media/FpFgL5JWAAU ... name=large
Not teeth but just small winglets for a smooth flow extraction from under the floor
here's an example of the W13 same thing but for the W14 they're closer to each other
Venturiation
Venturiation
103
Re: Mercedes W14
why do they keep running in the wet #-o
RZS10
359
Re: Mercedes W14
16 Feb 2023, 14:30
https://i.imgur.com/ODeB4Gw.jpeg
That's just the small winglet hanging from the mid-wing and has been introduced mid season last year.
F1Krof
96
Re: Mercedes W14
vs
Better contours on vertecies no?
Wroom wroom
Re: Mercedes W14
RZS10 wrote:
16 Feb 2023, 14:42
16 Feb 2023, 14:30
Oh I see! Thanks
I looked at the w13 version and I remember it vividly now #-o crazy what it takes to jog the memory sometimes
mantikos
mantikos
35
Re: Mercedes W14
16 Feb 2023, 14:30
It's been on the midwing since last year - aero only
e30ernest
e30ernest
27
Re: Mercedes W14
It does look like there is better outwash managing the front tire wake now.
gandharva
252
Re: Mercedes W14
16 Feb 2023, 14:30
This is nothing new. Here is the same part on W13:
/edit
Too late ;)
Venturiation
Venturiation
103
Re: Mercedes W14
e30ernest wrote:
16 Feb 2023, 15:02
looks the same
chrisc90
Re: Mercedes W14
Looks the same, maybe some less tighter airflow around the floor.
Still looks in the same area though.
How this compares to others would be a good comparison
Re: Mercedes W14
Using water trails as indication is not the happiest solution, it depends much on the amount of water on track, if it's raining at the time, etc. Here's a comparison from Japan last year, clearly Merc shot is not quite relevant...
SirBastianVettel
SirBastianVettel
16
Re: Mercedes W14
Isn't there also a significant difference in tire wake between the intermediate and extreme wet tires?
