AlphaTauri AT04
JPower
JPower
43
Re: AlphaTauri AT04
Goblin42 wrote:
22 Feb 2023, 02:28
is this porpoising or bumps on track ?
Ground effect aero will always have some form of bouncing. I don't expect any car to completely eliminate it.
Re: AlphaTauri AT04
Goblin42
57
Re: AlphaTauri AT04
Henk_v
Henk_v
88
Re: AlphaTauri AT04
Very ill fitting bodywork and a lot of screws. Looks like a rushjob, or this set of body panels was not worth getting 100% as they'll race something different.
Re: AlphaTauri AT04
Very RB18 front suspension layout
Re: AlphaTauri AT04
Blackout wrote:
22 Feb 2023, 20:43
https://motorsport.nextgen-auto.com/pho ... ev/022.jpg
Indeed. As much as they could with the push rod
SmallSoldier
SmallSoldier
486
Re: AlphaTauri AT04
The AT04 ready for testing:
Henk_v
Henk_v
88
Re: AlphaTauri AT04
Everybody is sure buzzing about this team.... #-o
Re: AlphaTauri AT04
Are they having separation before the air gets to their floor edge wing?
101FlyingDutchman
101FlyingDutchman
Re: AlphaTauri AT04
23 Feb 2023, 14:37
https://i.imgur.com/GKkBCPM.png
https://i.imgur.com/lqu6SQi.png
https://i.imgur.com/win7AqK.png
No I don’t think that’s separation. The floor edge wing will affect the air upstream as it’s showing right there. Without CFD it’s hard to see if that’s intended. They might be turning the air to induce vorticity
Re: AlphaTauri AT04
101FlyingDutchman wrote:
23 Feb 2023, 15:10
23 Feb 2023, 14:37
That makes more sense to me
Re: AlphaTauri AT04
What is causing so much downwash on the side of the sidepod?
Joe7218
Joe7218
Re: AlphaTauri AT04
25 Feb 2023, 14:43
https://i.imgur.com/AATbWRs.png
My guess is that there is a region of low pressure around the sidepod undercut (due to the curved geometry, think an airfoil surface turned on it's side). The air around the side of the upper sidepod is being sucked down into this lower pressure region.
Ozan
Ozan
Re: AlphaTauri AT04
25 Feb 2023, 14:43
look at the top of the mirror cover
Re: AlphaTauri AT04
23 Feb 2023, 14:37
Someone should tell all those Predators in invisible mode to look left and right before crossing the street.
