Ferrari F60
Astro1
Astro1
Re: Ferrari F60
Is it me or does the it look like the interaction between the upper diffuser channel and the rear crush structure is not very smooth at all!
It may be that Ferrari didn't have time but the design seems to allow for an upward turn similar to the RBR but it's not seen on the car.
The RBR design though similar clearly provides a better exit for the air from the upper channel IMO.
ISLAMATRON
Re: Ferrari F60
ISLAMATRON
Re: Ferrari F60
Seems like Ferrari is running a W-12
Astro1
Astro1
Re: Ferrari F60
:?: Hm....I wonder what that's for.
At first I thought that it was just a heat exit, but now there looks to be an actual circular "item" there. What could it be? Surely it's not a 3rd exhaust.
Would a single exhaust be permitted if a team wanted to run one? A sort of 8 into 1 collector?
mx_tifoso
mx_tifoso
Re: Ferrari F60
Isn't it just a relocation of the weird exhaust that used to come out of the rear-right sidepod back in '07 or '08?
bjpower
bjpower
-1
Re: Ferrari F60
Astro1 wrote::?: Hm....I wonder what that's for.
could it be to separate different air flows inside the car.
like keep the faster air from the rads away from possible slower air from kers cooling ?
di44ety
di44ety
Re: Ferrari F60
timbo
timbo
113
Re: Ferrari F60
translation? please... :roll:
Re: Ferrari F60
Kool.. so there are no anti roll bars in the front?
What is that shock that that connects the two levers at the top?
FLC
FLC
Re: Ferrari F60
They are explaining the new modification Ferrari have made to the F-60.
KERS system is made lighter; Massa will use a new chassis, the lighter one that Kimi have been using in recent races; The front suspension geometry is totally new,it required a new front crash test and is aimed at allowing better weight distribution (towards the front) and the front tyres to warm up quicker and improve the front end grip; A new front wing will be fitted; New wheel rim covers will be used with a new mounting system, to allow improved fitting.
mx_tifoso
mx_tifoso
Re: Ferrari F60
FLC wrote:They are explaining the new modification Ferrari have made to the F-60.
This is all explained in the news at the top of the page :wink: . In case someone hadn't noticed.
Astro1
Astro1
Re: Ferrari F60
Though not talked about in the video, if the animation is anything near correct, it looks like the rear crash structure is turned up and is more pronounced than before and closer to the RBR concept.
timbo
timbo
113
Re: Ferrari F60
Astro1 wrote:Though not talked about in the video, if the animation is anything near correct, it looks like the rear crash structure is turned up and is more pronounced than before and closer to the RBR concept.
Yes, noticed that too
mx_tifoso
mx_tifoso
Re: Ferrari F60
Raikkonen's seat and car at the British GP
siskue2005
siskue2005
70
Re: Ferrari F60
why is the seat in golden color??
i have seen the same in MS's car aswell!
Is it really made of GOLD!! :wtf:
