Red Bull RB19
Owen.C93
Owen.C93
189
Re: Red Bull RB19
Old:
New:
Looks like they've widened the inlet based on the mirror, but made it shallower. Should provide even more flow down the undercut.
Re: Red Bull RB19
Owen.C93 wrote:
27 Apr 2023, 18:25
Old:
https://i.imgur.com/W05R9Rp.jpg
New:
https://pbs.twimg.com/media/Fuu7S-zWwAY ... ame=medium
I'm pretty sure that they can't have widened the sidepod inlet.. if you look at the regulatory volumes at the front of the sidepod, the sidepod inlet would have to taper aggressively rearwards if it was made any wider, which it doesn't do.. Unless I'm mistaken
A major advantage of having the sidepod inlet set rearwards from the scoop is such that they can move the scoop upwards or downwards without having to change the sidepod inlet shape too much (eg having to widen it)
And just by eye I can't see from this angle that the inlet would necessarily be any wider
Re: Red Bull RB19
Interesting. The sidepod inlet is a lot smaller.
#ReleasetheADUO
Re: Red Bull RB19
It does look slightly wider, going towards Ferrari style a bit.
dren
228
Re: Red Bull RB19
Looks like the base of the inlet is pulled up but that could just be the angle. The strake under the mirror is altered; it now is just a rectangle profile.
Honda!
Re: Red Bull RB19
Vanja #66 wrote:
27 Apr 2023, 19:00
Yes, and wider. Is the mirror attached differently now? Otherwise I think the vane is in a similar location to last race, but the side pod itself is wide (which explains the extra distance between the mirror support vane, and the outside of the sidepod inlet.
#ReleasetheADUO
Re: Red Bull RB19
New
Old
Looks fairly similar in surface area, as expected. Pushing more air in the undercut likely has twofold influence - increasing outwash and overall flow rate towards the rear.
gandharva
252
Re: Red Bull RB19
If the vertical mirror mount is still at the same spot, the inlet is clearly wider now.
Re: Red Bull RB19
The front profile of the new scoop looks remarkably similar to the silhouette we saw on the low quality Silverstone shakedown video...
People were predicting higher and potentially wider inlet scoops for the launch version based on the shakedown.. and now they appear
vorticism
vorticism
449
Re: Red Bull RB19
Will this be a permanent change to the sidepod inlet or track specific?
With this change the inlet lip and the VG are no longer conjoined.
Added another comparison image below.
Vanja #66 wrote:
27 Apr 2023, 19:21
New
Previous:
Single louver exit per Fabrega (below).
Re: Red Bull RB19
After looking at all the pics in the thread and various images from the silverstone shakedown it seems very likely the baku spec inlets were used at the shakedown already. Not sure if anything can be concluded from that, but it supports the idea that RB are not rushing components to the car and instead focusing on being efficient with parts, which completely makes sense when there seems to be a sizeable advantage in pocket
Sieper
73
Re: Red Bull RB19
vorticism wrote:
27 Apr 2023, 20:50
Previous:
https://i.postimg.cc/jjjSYx9x/RB-susp-2.jpg
https://pbs.twimg.com/media/Fuu7SoUXgAQ ... name=small
https://pbs.twimg.com/media/Fuu7SLMXoAA ... name=small
I don’t think that’s a single louvre exit, just the entire plate not screwed down. It also has a gap along its bottom.
vorticism
vorticism
449
Re: Red Bull RB19
There's a relief outside of the aft end of the panel and the panel is taped on its bottom and leading edge. One exit is probably the result of changing the louver panel and not changing the panel it sits inside of; the last louver is built into the adjacent panel.
https://pbs.twimg.com/media/Fuu7R7cWAAA ... name=large
Re: Red Bull RB19
Is this old or new? I know they had some overhang of the front wing, off of the endplate, but I didn't know it was that much.
#ReleasetheADUO
Re: Red Bull RB19
27 Apr 2023, 23:01
https://i.postimg.cc/NjS9fyxK/image.png
I don't think it has changed since launch; it was pointed out at pre-season testing
26 Feb 2023, 19:19
Spotted a FW trick..
RB have created a Merc-like slot at the FW in their own way.
They create this by having an overhanging piece of FW that extends beyond the endplate and 'cuts in' to connect to the endplate. And they position the downwashing fin that a few teams have at the rear part of the endplate presumably helping this function as the endplate slot did last year.
https://i.imgur.com/4hhyVrA.jpeg
The flap adjuster is also cranked outboard too compared to the rb18, as well as some aggressive curvature changes potentially causing more vortex shedding in this region..
https://i.imgur.com/o61gcnM.png
