In these two image, the top one doesn't immediately look like Monaco, possibly Miami ? That's from track topography view.Venturiation wrote: ↑29 May 2023, 23:13Don't know if it was noticed but they tested both configuration in practice
I just verified and there is both versions in MonacoFarnborough wrote: ↑30 May 2023, 09:05In these two image, the top one doesn't immediately look like Monaco, possibly Miami ? That's from track topography view.Venturiation wrote: ↑29 May 2023, 23:13Don't know if it was noticed but they tested both configuration in practice
They are two very different levels of RW too! Also didn't think it was running anything like that low a level at Monaco
And front suspension arm top angle doesn't look consistent with the new location now in use (that's in the top image) and only at Monaco.
We will see in spain they will compare both again and for sure use aero rakes wich was impossible for monacoFarnborough wrote: ↑30 May 2023, 09:51Thank-you, yes you can see in that collection more instances, one plan view of it rounding the Portier section over the bricks, with narrow/original arrangements.
LW crashed it with narrow/original cannon exit configuration. His comments about going against advice of tech team in FP3 I wonder if they are related to that difference ?
Mercedes were regarded as the leader when it came to trick hydraulic suspension systems. When all of those were remove, I think they just forgot some the basics because they hadn't used them for so long.Hoffman900 wrote: ↑26 May 2023, 14:59The front wishbones treat the air for everything behind it, so it’s understandable they would have to change substantially with a big change of concept.AR3-GP wrote: ↑26 May 2023, 14:51I think I mentioned this about the RB a long while ago. That the angle of the upper wishbone triangle was perfectly aligned with the floor leading edge as if they were using it like a fairing to turn air down towards the floor LE (the nosecone is generating some upwash)
The anti-dive thing still blows my mind and makes my head hurt. I can open up racing chassis engineering books from the 1970s and it’s talked about in depth and they have understood aero pitch sensitivity from day 1 - most of the early aerodynamicists came from aerospace anyway, but Steve Nichols has talked about it on the 1980s cars, active suspension was obviously a solution, Willem Toet as mentioned earlier gave examples, etc. NASCAR and Indy Car (before the chassis became spec) used asymmetrical anti-dive to help the cars handle on the ovals, every production car for just about ever has an element of anti-dive. It’s rudimentary stuff and the implication that Mercedes forgot something that current engineer’s grandparent’s age knew is a bit silly. There is no silver bullet on any of this.
The problem is just about anyone can create a youtube or twitter channel and parrot something they just learned about but don’f fully understand, and the media just eats it up because they don’t know ant better and because it “kinda sorta sounds plausible / smart”.
I feel this is clouded by more recent iteration of MB F1 chassis. While I agree with Hoffman about anti dive geometry etc, the knowledge and use of, the extent to which they wish to build in this characteristic and all that entails in plus or minus attributes.Martin Keene wrote: ↑30 May 2023, 13:09Mercedes were regarded as the leader when it came to trick hydraulic suspension systems. When all of those were remove, I think they just forgot some the basics because they hadn't used them for so long.Hoffman900 wrote: ↑26 May 2023, 14:59The front wishbones treat the air for everything behind it, so it’s understandable they would have to change substantially with a big change of concept.AR3-GP wrote: ↑26 May 2023, 14:51
This about as close as you can get to a B spec car in the cost cap era. The changes to the cooling systems probably entailed modifications to the chassis to ensure the repackaging of the cooling systems didn't impact the performance or reliability of the Power Unit and other systems. Rather than a B spec car, I guess you could argue that the W14 is a development platform/test mule for the 2024 car.PlatinumZealot wrote: ↑30 May 2023, 04:10The car is not a W14B guys. It is the same chassis. The upgrades are all standard fare.
This would entail a new crash test (certainly for side impact, possibly for rear), whatever they have done at the front of the chassis to cater for the new suspension mount positions I bet that they have done everything possible to avoid a fresh round of crash tests. Budget cap and all that…taperoo2k wrote: ↑30 May 2023, 17:23This about as close as you can get to a B spec car in the cost cap era. The changes to the cooling systems probably entailed modifications to the chassis to ensure the repackaging of the cooling systems didn't impact the performance or reliability of the Power Unit and other systems. Rather than a B spec car, I guess you could argue that the W14 is a development platform/test mule for the 2024 car.PlatinumZealot wrote: ↑30 May 2023, 04:10The car is not a W14B guys. It is the same chassis. The upgrades are all standard fare.
