Ferrari SF23
LM10
LM10
122
Re: Ferrari SF23
Vanja #66 wrote:
26 May 2023, 22:27
I think it will be easier to sort out the suspension with 2024 car than to change the whole aero approach. Oversimplified as it may sound, in my view Ferrari aero coupled with RB suspension would be an unbelievable car.
Your last sentence made me drool. :lol:
Let’s hope they manage to couple their aero with RB-like suspension next year.
Looking at other mistakes they keep doing like yesterday’s grid penalty for Charles because his race engineer was dreaming - they’ll need an “unbelievable” car to compensate for that anyway…
ing.
67
Re: Ferrari SF23
Vanja #66 wrote:
26 May 2023, 18:41
Wonderful to see the floor. Ferrari shaped their diffuser keel for massive pressure recovery and drag reduction, not really for downforce. They could add a few DF points there easily. Also, and this is clear, they are pushing with their original floor shaping as last year (no surprises there), no specific diffuser kicks like RB/AMR and a clean profile to maximise overall floor downforce.
As a result, I don't think they are benefitting with added air volume through the mouse hole as much as RB/AMR, so switching to downwash sidepods would not help them at all. They need to sort the suspension and tyre usage during the race, otherwise they will never use the full potential of the car in any race.
So, if they do add the few DF points of DF, will they lose the drag reduction benefit and be back where they were last year—with a deficit to RB on max. velocity? And, I note in the RB19 thread, wondering if RB are using what looks like the aft-most, second kick/venturi to maybe choke the flow to the diffuser when at low rear ride height to get their high Vmax?
Also, maybe the Ferrari design is just too reliant on maintaining the flatness of the platform that the restrictively regulated suspension cannot cope with—especially as regards pitch sensitivity, per my comment below…
Vanja #66 wrote:
26 May 2023, 19:19
Farnborough wrote:
26 May 2023, 18:50
Also that lowest area being so flat looks to make it very sensitive to height above ground, with much variance in that ride height it looks to be very peaky without much in the way of mitigation at all.
More of an "on~off" light switch type of interaction. Either it's making load or not much to speak of.
Both diffuser and wing in ground effect have the same nature, both are very sensitive to ride height and peak performance. Both are either working great or not good at all (for F1 performance level). Likewise, both Ferrari and RB/AMR concepts work well only when the car is at optimal ride height. The difference is that RB is keeping the car low at the lowest speeds, next one is AMR judging by its performance and Ferrari is at best third in this regard.
https://d3i71xaburhd42.cloudfront.net/d ... ure3-1.png
https://www.researchgate.net/profile/Jo ... l-with.png
Though these charts talk to performance as a function of ground clearance, they don’t show variations in DF—or CoP shift—as a function of pitch attitude, which I believe would show the flat bottom as more sensitive than a “shaped” floor.
christian.falavena
Re: Ferrari SF23
New mirror
Venturiation
Venturiation
102
Re: Ferrari SF23
We might see the new sidepods today if they put them outside
gordonthegun
254
Re: Ferrari SF23
This change is insignificant from an aerodynamic point of view.
I think it's for weight reduction.
Re: Ferrari SF23
It's a very small change to the mirror at best.
christian.falavena
Re: Ferrari SF23
AR3-GP wrote:Image
Is the mirror new? It looks quite similar to Monaco.
Look at the upper profile
Re: Ferrari SF23
christian.falavena wrote:
31 May 2023, 20:38
AR3-GP wrote:https://pbs.twimg.com/media/FxETpT7WwAA ... =4096x4096
I see now, the span has been shortened on the upper winglet. I updated post. It's a very minor change.
gordonthegun
254
Re: Ferrari SF23
Was that point with an open lid under the sidepod inlet already there?
Re: Ferrari SF23
An unexpected return of 2022 launch spec wing, mid/high downforce. We'll see if they stick with it or choose another spec tomorrow.
christian.falavena
Re: Ferrari SF23
gordonthegun wrote:Was that point with an open lid under the sidepod inlet already there?
Air refill slot. Always there
Z-one
Z-one
Re: Ferrari SF23
Vanja #66 wrote:
01 Jun 2023, 09:58
https://pbs.twimg.com/media/FxhRrWRWIAI ... name=large
2022 Bahrain Spec
gordonthegun
254
Re: Ferrari SF23
In this photo by Giorgio Piola the car has the old mirror.
It seems from the strip on the suspension hub cover (white LEC, yellow SAI) that Carlos has the new mirror and Charles the old one:
ing.
67
Re: Ferrari SF23
Vanja #66 wrote:
01 Jun 2023, 09:58
The sidepod cooling package seems to be similar. Most likely no major change or waterslide design, although without comparing looks like maybe just a deeper undercut at the max. cross section of the car(?).
Expected visible change to sidepods (as predicted in Italian press) could be what, then? Possibly a more neutral or downwashing trailing edge to the sidepods. Probably not a cannon-type cooling exit.
Re: Ferrari SF23
Vanja #66 wrote:
01 Jun 2023, 09:58
Last year they ran full Monaco spec, this season wether because the track changed or something else they are going with less drag but not all the way to the current mid wing (as of yet).
Ps:Looking at Fabrega's photos, RBR, Mercedes and Aston are in full Monaco config.
