2023 Scuderia Ferrari F1 Team
CaribouBread
CaribouBread
101
Xyz22 wrote:
02 Jun 2023, 18:28
https://pbs.twimg.com/media/FxoWrJnXsAI ... name=large
Long season ahead
That 18.6 at the end of a 10 lap soft stint (iirc) is ominous for a lack of a better term :oops: :shock:
Xyz22
Xyz22
125
CaribouBread wrote:
02 Jun 2023, 18:33
Xyz22 wrote:
02 Jun 2023, 18:28
Long season ahead
The RB19 is in a completely different league. Not surprising.
dialtone
dialtone
139
LEC v VER:
Hard to say why it happens, aside from RBR being a better car, but mostly VER gains in the high speed corners, specifically T3, T11 and T14, where he simply keeps the pedal down more.
Long run pace of the first group:
SAI and LEC both have very good pace, it's not close to VER but their first stint was on the test tyre which is a hard compound equivalent and the degradation on the softs is equivalent to Max. I think the race might show some small improvement from Ferrari.
This graph has the outliers removed, so a bit clearer how the laptimes evolved. Box plot shows how Ferrari are much improved here in terms of long run pace.
Xyz22
Xyz22
125
Leclerc has to lift in turn 3?
search
02 Jun 2023, 18:58
https://i.imgur.com/cq8wy6y.jpeg
degradation looks alright, which is a positive indeed. Pace looks about equal with Mercedes, I would say, if you take the fuel effect into account. Sainz burned 13 laps of fuel already before switching to Softs, Leclerc 8.
Juzh
161
Xyz22 wrote:
02 Jun 2023, 19:24
https://pbs.twimg.com/media/FxocdOiWIAU ... name=large
They're loaded with fuel I think, more-so what others. No way they're lifting in quali, might as well go home.
Juzh wrote:
02 Jun 2023, 20:31
Xyz22 wrote:
02 Jun 2023, 19:24
Ferrari isn't running their high downforce wing here. I'm seeing bigger lifts in T3 and T9 in the telemetry compared to the F1-75.
Beware of T-Rex
Hoffman900
Hoffman900
242
02 Jun 2023, 20:42
Juzh wrote:
02 Jun 2023, 20:31
Xyz22 wrote:
02 Jun 2023, 19:24
Compared to what F1-75 session? Also, temperature, wind?
f1316
88
This all seems tentatively positive. Charles said much the same - i.e. the feeling is good but still work to be done.
It doesn't mean they will have Red Bull pace all of a sudden, but it does seem (on VERY initial data) a bit more stable, a bit more predictable.
Hoffman900 wrote:
02 Jun 2023, 20:51
02 Jun 2023, 20:42
Juzh wrote:
02 Jun 2023, 20:31
It's never going to be a like for like comparison of course.
Beware of T-Rex
Xyz22
Xyz22
125
02 Jun 2023, 20:59
Hoffman900 wrote:
02 Jun 2023, 20:51
02 Jun 2023, 20:42
If the fuel load is the same this is embarrassing.
Hoffman900
Hoffman900
242
02 Jun 2023, 20:59
Hoffman900 wrote:
02 Jun 2023, 20:51
02 Jun 2023, 20:42
I think qualifying is the only time you can compare, because that’s the only time you know they're actually trying, the PU’s are cranked up, and the fuel loads are low.
Hard to read into sessions that are glorified testing programs.
Hoffman900 wrote:
02 Jun 2023, 21:04
02 Jun 2023, 20:59
Hoffman900 wrote:
02 Jun 2023, 20:51
Normally it can be difficult to compare, but there's an odd bit in the data that is worth attempting to reconcile. The SF23 is carrying a lot more speed through Apex in places like T4, T7, T10 than F1-75, yet the SF23 is taking much bigger lifts in T3 and T9. How can both of these things happen at the same time?
Beware of T-Rex
Hoffman900
Hoffman900
242
02 Jun 2023, 21:07
Hoffman900 wrote:
02 Jun 2023, 21:04
02 Jun 2023, 20:59
1) They’re sand bagging or at least just not putting wear on the car. There are two spec SF-23’s in this session. Also Charles was running the test tire for a chunk of it. It was a testing session.
And/or
2) they’ve determined with the way the PU deployment works they can gain more lifting and recharging and deploying elsewhere, especially with the loss of the chicane.
Lots of things. We’ll find out tomorrow.
