Red Bull RB19
vorticism
323
Re: Red Bull RB19
Inspection jig with optical inspection targets used for setting the car up.
π“„€
atanatizante
125
Re: Red Bull RB19
... and part 2:
Jesus
vorticism
323
Re: Red Bull RB19
atanatizante wrote: ↑
23 Jun 2023, 20:27
So he thinks it is mostly be about aero. Maybe I'm in good company.
vorticism wrote: ↑
08 Apr 2023, 23:38
I agree. Anti-dive can only be a partial solution. The suspension still deflects vertically upon load transfer regardless of the arm inclination (within reason). It makes me think it's more about aero. The RB16 had a flat top arm, and a slightly inclined lower arm (the arms diverged rearward instead of converge as on the RB18/19), which provides the opposite sort of caster change that the RB18/19 would provide. This might be a change in chassis/suspension philosophy, or simply an indication that suspension design plays second fiddle to aero.
https://abload.de/img/detailsdukmz.jpg
Is it true when he says that excess anti dive can provide ride height increase?
π“„€
deadhead
64
Re: Red Bull RB19
β€œ The Red Bull RB18 & RB19 has a diffuser that keeps the rising airflow low.
The wake, which has less interaction with the rear wing, reduces drag.
If the air velocity at the kick point does not decrease, the floor downforce will not decrease.”
Re: Red Bull RB19
Not making sense.
Linking the diffuser and the rear wing has proven beneifits. Old tried and trusted solution.
The steps in the floor are not new either. Teams ran similar steps, in the form of concave diffuser decades ago. Does the same thing.
Re: Red Bull RB19
deadhead wrote: ↑
28 Jun 2023, 14:32
That explanation is completely wrong. :)
https://www.linkedin.com/pulse/uncovere ... novi%C4%87
The diffuser has a complex curvature, after the kick there is a concave surface where there is some pressure recovery due to a drop in expansion. At the edge and under the beam wing, there is a specific flick on the floor, introducing another area of low pressure, which especially works together with beam wing to further drive the whole floor by generating big suction zone. When you have a big suction zone here, the whole mass of air under the floor also speeds up to reach this low pressure zone. However, these two points (underfloor kicks and diffuser design) are not the only secret.
Re: Red Bull RB19
Vanja #66 wrote: ↑
28 Jun 2023, 14:46
Disinformation campaign by our RB friends :wink:
SiLo
139
Re: Red Bull RB19
Looking at that picture upside down absolutely scrambled by brain.
Felipe Baby!
Re: Red Bull RB19
That user has blocked me on Twitter in the past for pointing out some errors in what they were posting (kindly and with good evidence). I don't think they warrant being posted further
deadhead
64
Re: Red Bull RB19
organic wrote: ↑
28 Jun 2023, 16:46
Noted.
Re: Red Bull RB19
Re: Red Bull RB19
Nothing jumping out at me
Re: Red Bull RB19
organic wrote: ↑
30 Jun 2023, 13:00
They used the word "subtle" with regards to a change in suspension wishbone shroud (presumably the one with the driveshaft in it), so probably not going to be caught by a relatively long range shot from that angle.
Re: Red Bull RB19
Re: Red Bull RB19
