General aero discussions
Re: General aero discussions
Smokes wrote: ↑
04 Jun 2023, 00:41
Why did the mercedes team continue a bad aero concept for so long. The performance on the track did not tally with the simulation models so something must be off.
did there 1/4 scale tunnel models not show porposiing and floor flexing and how the tyre disortorted under load?
You could run fea and cfd to compute how the body deflects under and aero load but it would use too much computational power.
Because they really weren't sure why the car wasn't doing what their tools said it ought to do. So they ran last year as a correlation and test exercise. They swapped directions late in the winter when they realised where some errors were but then had to run the W13 (called W14 but obviously wasn't) in a tarted-up form until the real W14 could be built.
Mtshali_Motorsport
Mtshali_Motorsport
Re: Red Bull RB19
PlatinumZealot wrote: ↑
19 Apr 2023, 04:25
So Andrea Stella released some very interesting information today...
RedBull floor concept utilizes and exploits "vertical" flow structures underneath it. Apparently, they are getting better downforce doing it. Most teams you can imagine committed to "horizontally" sweeping flow structures under the floor.
I'm not sure how to interpret this, but I imagine Adrian Newey has "double-stacked" two or more vortices vertically, one on top of the other, to build interior "curtains" running to the rear of the floor. Other teams apparently roll up vortices that are laterally beside each other instead....
Quite interesting. And you can see why Mclaren had to go back to the drawing board to exploit this as this a HUUUGE change in design if not yet a change a philosophy.
I think the so called vertical flow structures are mimicking the vertical fences on the diffusers that were a key part of the previous generation of cars.
:? Maybe my interpretation could be far off but hopefully someone could chime in on this.
That can be true. The redbull has a low height diffuser throat. It may be lower so that vertical divising structures can be attached?
A cool post
vorticism
vorticism
334
>boringdotcom
Mark remembers a better time for brake duct modellers.
vorticism
vorticism
334
Re: Red Bull RB19
Something which hasn't got much discussion yet in the '22 formula is the large flat central floor area. This is new and unique to this formula--previously (2009-2021) the lowest part of the floor (the reference plane) was not much larger than the plank.
Given now a larger % of the floor is only [plank thickness + ride height] above the track, this should explain the use of the Red Bull keel notches/steps. VGs for this lowest plane, and dialing in of the airflow at its periphery.
2009-2021:
2022-2023:
Andi76 wrote: ↑
03 Jun 2023, 07:40
Edit: typos.
jjn9128
779
Re: Red Bull RB19
vorticism wrote: ↑
28 Jun 2023, 20:20
Given now a larger % of the floor is only [plank thickness + ride height) about the track, this should explain the use of the Red Bull keep notches/steps. VGs for this lowest plane, and dialing in of the airflow at its periphery.
2009-2021:
2022-2023:
Andi76 wrote: ↑
03 Jun 2023, 07:40
The plank is narrower than pre-22. It used to be 300mm wide. It's now 250mm.
#aerogandalf
vorticism
vorticism
334
Re: Red Bull RB19
Indeed, which also contributes to the increase in the % of reference plane area (not masked by the plank) relative to the total floor area. I estimate the max ref plane width on the RB19 to be ~800 mm.
This perhaps worth noting because the 2022 RB18 was revealed to have the widest reference plane when the floors were seen through the season (compared to Ferrari and Merc).
This center floor area is also shaped approximately like the X2014 car from Gran Turismo. So the FIA audits of Newey's hobbies may need to go back a bit further than the Valkyrie. :D
jjn9128
779
Re: Red Bull RB19
vorticism wrote: ↑
28 Jun 2023, 20:49
Maximum width of the reference plane/boat is 750mm.
https://cad.onshape.com/documents/e62d7 ... f345c90e40
#aerogandalf
vorticism
vorticism
334
Re: Red Bull RB19
+1 thanks for the link. 6% error with my web browser ocular metrology, not bad. I do think Merc & Ferrari were running narrower "boats" last year in order to smooth/straighten the path of their tunnels; at least it LOOKED that way. They've hence gone away from that.
The % of total DF from this central area might not be insignificant. Question is: is this a good feature to dial in? Does having a large area of the floor floating ~15-20mm above the track produce good downforce or is the flow inherently so limited that it's relatively WEAK compared to the tunnels/diffuser. Regardless, RB were the only one who chose to optimize structures in that area, from the beginning.
Re: Red Bull RB19
vorticism wrote: ↑
28 Jun 2023, 21:27
The % of total DF from this central area might not be insignificant. Question is: is this a good feature to dial in? Does having a large area of the floor floating ~7-10mm above the track produce good downforce or is the flow inherently so limited that it's relatively WEAK compared to the tunnels/diffuser. Regardless, RB were the only one who chose to optimize structures in that area, from the beginning.
If you can get the airflow to be "happy" under there, running the boat close to the track will give extra downforce. It's basically a mini version of the old flat floors from when the plank was introduced in '94.
RB's detailed work on the boat compared to other teams is very noticeable in 2022.
Re: Red Bull RB19
vorticism wrote: ↑
28 Jun 2023, 21:27
The shape of the flat area seems to be about guiding the lateral expansion of the flow, and the flicks/steps do some other stuff no-one other than the designers is quite yet sure of.
vorticism
vorticism
334
*nudge, nudge* "And we're back."
29 Jun 2023, 06:36
vorticism wrote: ↑
28 Jun 2023, 21:27
I think they are/were working this flat area more than other teams with those details (flow under these flat floor areas) i.e. less about the tunnel behavior; that is just my speculation, though.
29 Jun 2023, 06:36
vorticism wrote: ↑
28 Jun 2023, 21:27
Those flicks/steps are somewhat reminiscent of similar structures used in similar locations on the Valkyrie:
Of course, these details were always covered up / smoothed out on the show cars, but they are there on the real thing.
AR3-GP wrote: ↑
06 Sep 2024, 20:08
If they cannot see the issue in the windtunnel, is it possible that the balance problems arise from the transient behavior of the aerodynamics? (i.e aero structures fail or don't respond as expected when the floor is moving between states of pitch, roll, and ride height)?
The mechanism that moves the windtunnel model in the windtunnel to the different positions of pitch, roll, and ride height is not a high speed motion system. It is slow. It's not designed to reproduce dynamic motions or study transient aero (measuring aero in a dynamic situation like shifting floor as the car enters corner and driver trail brakes and steers). It can only put the car into "states". If aero structures behave unpredictably or collapse during the transient ride stages, then it could explain the poor balance which is not apparent from the windtunnel data.
In other words, they know they have load at ride height A and at ride height B, but they can't check in the wind tunnel how the load transitions from ride height A to ride height B in a dynamic scenario like entering a corner. This could be where the failure in the real world is.
That's a good question, but there are two more important ones that precede it:
- what is the angular yaw limit of the work section (where the model and rolling road are)
- how stiff is the rolling road in extreme low ride height cases
With previous cars, you had loads of vortices in bargeboard area which generated the bulk of the front floor downforce and you had diffuser and vanes that generated the rear bulk. Neither was extremely dependant on complete flow stability on majority of the floor as the floors today are dependant. Wings were also more important relative to the floor and their performance in yaw is typically more stable than the floor. All of this meant that yaw limit in WT was less impactful and easier to correlate with CFD and thus translate to CFD simulations under yaw greater than WT yaw limit. Today, there seem to be quite a few challenges with floor performance under large yaw and how this translates to flow stability while cornering.
As for rolling road stiffnes, I think the subject is quite clear :D
AR3-GP wrote: ↑
06 Sep 2024, 21:09
KimiRai wrote: ↑
06 Sep 2024, 20:45
Sorry if it doesn't make any sense, I have no clue, but could McLaren's new wind tunnel have something that helps with this?
I don't know if it is the case for Mclaren, but from a technology point of view, these newer wind tunnels probably have faster model motion systems and if anything, the Red Bull windtunnel could potentially have a slower model motion system because it's so old (unless the motors inside the motion system had been upgraded since it was built)
There is actually a regulation addressing this aspect of the windtunnels. It is a speed limit for the wind tunnel's model motion system. This comes from Appendix 7, section 3e of the 2024 Sporting regulations:
I don't know how these model motion system speed limits compare with the rate of change of the ride height and yaw in the real world in a typical cornering scenario, but in theory you would be better off if you could replicate them in your windtunnel. It would add an additional dimension to your understanding.
Those limits are quite big, rolling rate limit of 1Β°/s is not as bad as the same yawing limit, but it's still probably 3-5 times slower than what happens to the real car. Front and rear ride height are same, 33mm/s is quite slow. I expect this is also 5-10 times slower than actual rates. The longer lasting period of time on track is the state itself, not the transition to that state.
If transition rates from state to state matched the order of magnitude of what happens on the track, I think WT models and moving mechanisms would have to be far sturdier to support much bigger dynamic loads. This would also mean much more powerful (thus bigger) servos that provide power to those mechanisms.
Replied to another thread, as this has nothing to do with RB20 itself :)
