Mercedes W14
Re: Mercedes W14
Interesting...
Re: Mercedes W14
SiLo
144
Re: Mercedes W14
I have noticed how compared to Red Bull and other teams that are using the beam wing to enlarge the diffuser, Mercedes appear to be going a different route. The roof of their diffuser is quite flat, rather than having a late expansion ratio, where its smaller a bit further inboard.
Felipe Baby!
K1Plus
K1Plus
Re: Mercedes W14
SiLo wrote:
25 Aug 2023, 14:47
Could this be the reason they lack the rear end?
Stu
Re: Mercedes W14
SiLo wrote:
25 Aug 2023, 14:47
In theory….
They are being very aggressive with the diffuser (as was common in the old regulation set).
mwillems
Re: Mercedes W14
-Bandit
ValeVida46
Re: Mercedes W14
Looks like some minor mods to the sidepod
Re: Mercedes W14
The fiddly bits under the mirror are gone again.
Beware of T-Rex
scuderiabrandon
111
Re: Mercedes W14
31 Aug 2023, 19:17
It seems they only appear at high dwf circuits
prox
Re: Mercedes W14
Those sidepods look narrower and more vertical along the side
Gabriox
Gabriox
Re: Mercedes W14
I thought so as well. Maybe it's just the angle but it seems slightly different if you compare the 2 photos below carefully
Old
Monza spec
pursue_one's
97
Re: Mercedes W14
Single element beam wing on the W14
GrizzleBoy
GrizzleBoy
35
Re: Mercedes W14
I don't know why. Maybe I haven't been paying attention or something but the sidepod inlets look a bit strange in these pics.
Are they the same?
Farnborough
Farnborough
152
Re: Mercedes W14
Thats a very interesting look at some of the changes that they've moved onto their car.
The shift in front suspension, aero treatment of suspension arms as conditioning vanes to floor and pod geometry, the strakes at floor entrance and treatment of the first strake from chassis centre and its extension forward.
That first (nearest to centre of car) strake appears to hold some considerable influence on performance of diffuser characteristics with many team making obvious shift here. Looks like it may hold greater primary influence over accumulation curve of floor download, increase in input flow could flatten/cap that curve response to prevent rear end characteristics going into porpoising territory.
Re: Mercedes W14
Rear shot of the Single element BW
