2023 Scuderia Ferrari F1 Team
FDD
FDD
83
List of max speed per driver??
scuderiabrandon
111
jambuka wrote:
01 Sep 2023, 18:25
01 Sep 2023, 18:14
Sainz's top speeds in FP2 were in another category. They can definetly fight for pole, I change my vote.
Were Leclerc & Sainz on different engine modes ?
Sainz better top speed up to Ascari and Parabolica (5kph on both).
Perhaps some engine mode differences, I can't say for sure? Hope it is not due to reliability.
You can see a key difference in the driving styles aswell. Charles likes rotating the car on throttle where Sainz would completely lift rotate the car and get back on power. This also something that is quite evident through S2-S3 at Austria. I'm quite confident in saying this is the exact reason the SF-23 doesn't suit LEC style, to keep the minimum cornering speed high you need a car that rotates well in the mid corner which is not the case with the SF-23.
scuderiabrandon wrote:
01 Sep 2023, 20:14
jambuka wrote:
01 Sep 2023, 18:25
01 Sep 2023, 18:14
https://ibb.co/ZhhMynv
https://ibb.co/LS9W9Ch
Check Leclerc's lap 7 on the medium tire.
codetower
So what were the top speeds for each? And did Carlos have a higher DF rear wing?
scuderiabrandon
111
codetower wrote:
01 Sep 2023, 21:22
In FP2 they were running the same rear wing and beam wing configuration
Xyz22
Xyz22
124
Leclerc with interesting laps in high fuel configuration.
scuderiabrandon
111
Xyz22 wrote:
01 Sep 2023, 22:02
https://pbs.twimg.com/media/F49rGYQXYAA ... name=large
This is hilarious man. How can the feedback be so different, surely they aren't galaxies away in terms of how the cars are setup. Again I feel like the biggest differentiator is the driving styles ? #-o
01 Sep 2023, 22:09
Xyz22 wrote:
01 Sep 2023, 22:02
https://ibb.co/ggtZQW7
This is hilarious man. How can the feedback be so different, surely they aren't galaxies away in terms of how the cars are setup? #-o
Carlos is a more optimistic person, typically.
Xyz22
Xyz22
124
01 Sep 2023, 22:09
Xyz22 wrote:
01 Sep 2023, 22:02
It's common knowledge (for who follows F1) that Leclerc and Sainz requires very different things in terms of balance to be competitive. It's also widely known that Sainz is quite good at dealing with cars that have quite a lot of understeer, which is the case of the SF 23.
You pretty much can't use the front end of this car.
scuderiabrandon
111
01 Sep 2023, 22:11
01 Sep 2023, 22:09
Xyz22 wrote:
01 Sep 2023, 22:02
I'm more so referring the the fact that Carlos says the long runs need improvement and the short runs look solid and Charles reports the complete opposite.
S D
01 Sep 2023, 22:09
Xyz22 wrote:
01 Sep 2023, 22:02
Leclerc may or may not be fine with the long term pace but wants to shoot for pole position and wants to get a better balance.
Sainz wants to work on race pace. IMO better balance will also give race pace.
I don't really see them a miles apart.
aleks_ader
90
Will write this now. Whole race operations should get fired how the heck u dont comply with race director rules...
JPower
JPower
43
Not bad for a #2 driver. :wink:
scuderiabrandon
111
No further action according to Chris Medland
Thats P1 and P3
SAI very clean weekend so far, looked more comfortable all weekend.
Charles confirmed it was his choice to go out first, which cost him pole for suree. Very close and good to see both drivers competitive. Hope we hold up in the race.
Sainz haha. Impressive. Talk about pressure!
