Force India VJM02
Will the VJM02 improve the teams constructors standings compared to '08?
Poll ended at 15 Mar 2009, 22:22
Yes
64
73%
No
27%
Total votes: 88
scarbs
scarbs
393
Re: Force India VJM02
Oops missed the link, thats the new front wing from Silverstone
bjpower
bjpower
-1
did they run it a silverstone?
or just test it
zgred
ISLAMATRON
diffusers gone wild!!!!
timbo
timbo
113
ISLAMATRON wrote:diffusers gone wild!!!!
You ain't seen next year cars.
That's if DDD loophole won't be closed
ISLAMATRON
They really need to because it is obviously getting out of hand
kilcoo316
kilcoo316
21
Spencifer_Murphy wrote:While the angle of incidence is the primary variable for stalling, airspeed does have an influence as higher speed flow is more likely to remain laminar.
Higher speed flow is more likely to have a turb B.L which will result in less seperation.
Spencifer_Murphy wrote: I recently performed some windtunnel tests on an aerofoil (NACA 23012) at university as part of a much larger investigation for a final year project.
When running the windtunnel at 8m/s the stalling angle of the aerofoil was 11degrees.
When running the same aerfoil at 28m/s the stalling angle was almost 16 degrees.
:shock:
I knew there would be some difference with speed (due to lam/turb BLs as I mentioned), but I thought it would be under a degree! Certainly nothing like that!!!
Edit: Out of interest, how did you measure the loss of lift? Pitot probes or by weight balance?
(I'm wondering is the "stall" actually a result of an unwinding of the starting vortex rather than seperation)
If you used pitot probes, was there any kind of relationship when the BL tripped to turbulent and the seperation point moving down the chord length?
Spencifer_Murphy
kilcoo316 wrote:Out of interest, how did you measure the loss of lift? Pitot probes or by weight balance?
I used a weight balance to measure lift force as it turns out. I do believe the stall was indeed caused by flow separation as I used strings attached to the wing surface for flow visualisation (the tunnel used was closed circuit so we can't really use smoke vis - altho we did when Richard Hammond came round to film some footage for the TV series "Richard Hammonds Engineering Connections")
Anyway, the flo-vis seems to show separation.
Silence is golden when you don't know a good answer.
Michiba
Michiba
zgred wrote:Image
looks like rocky balboa
I get it.. :)
I think* the Force India is about on par with Ferrari right now. The drivers and strategist just need to get used to the car.
zgred
Saribro
Saribro
Someone surely pulled out the copy/paste tool :):
zgred
Saribro wrote:Someone surely pulled out the copy/paste tool :):
True, True, Saribro
zgred wrote:Image
ESPImperium
ESPImperium
64
If force india went to a lower nosecone posistion, i think it could futher improve the front end of that car. The wing already has a massive ammount of downforce on it, so the next thing for development is probably the nosecone.
Giblet
Giblet
I wonder about that..., most of the teams have been raising, flattening, and widening the nose. The only team not doing that is Brawn.
FI's main strength seems to be their lack of drag, as they always seem to be in the top 3-5 for speed traps, en when their laps are slow.
