2026 F1 Cars - General Thread
Re: 2026 F1 Cars - General Thread
Zynerji wrote:
Tue Aug 22, 2023 11:47 pm
Tue Aug 22, 2023 11:35 pm
Continuously variable aero sounds like an awful idea.
Agreed. And the catastrophic failures could be deadly to drivers and fans.
Any such system would need to be designed to fail "high downforce". That would mitigate most failures.
mzso
mzso
66
zioture wrote:
Wed Aug 23, 2023 9:19 am
F1 SPRAY GUARD Howmay be in real
It has its own thread.
wuzak
wuzak
470
F1 aiming for a 50kg weight reduction for 2026
https://www.autosport.com/f1/news/sat-f ... /10517806/
Seems there will be an awful lot of trimming of dimensions to get the 50kg saving, especially if rumours about much heavier batteries and cooling packages are to be believed.
BlueCheetah66
BlueCheetah66
33
Only a 50kg weight reduction is so disappointing. I was expecting much more. It is basically back to the 2021 level which is still too heavy.
mzso
mzso
66
wuzak wrote:
Sat Sep 09, 2023 10:58 am
I'd applaud that. But somehow I don't think it will be too significant. And the cars will still behave like very fast buses.
BlueCheetah66 wrote:
Sat Sep 09, 2023 5:54 pm
Well if the length would be much shorter it could mean a lot. But I don't see it happening.
wuzak
wuzak
470
mzso wrote:
Sat Sep 09, 2023 8:50 pm
I think it was suggested that the maximum wheelbase would be 300mm shorter - 3,300mm, down from 3,600mm.
I would hope for even shorter.
What worries me is that the cornering performance will be reduced, but the straight line performance will not be raised enough to compensate.
Personally I don't care if the cornering speeds get worse. The cars have to get more raceable and less unwieldy first and foremost
Astro85
Astro85
Is it possible to get smaller and faster cars than today's monstrosities?
mzso
mzso
66
wuzak wrote:
Sun Sep 10, 2023 1:33 pm
And why is that worrying. Laptime doesn't translate to good racing.
Astro85 wrote:
Sun Sep 10, 2023 3:01 pm
Naturally. But we're unlikely to get them.
Zynerji
111
We need a new pinnacle series. F1 is hopeless for so many reasons. These 2026 cars don't sound interesting -at all- to me.
I took a year off in 2018. Maybe it's time for a few more.
wuzak
wuzak
470
mzso wrote:
Sun Sep 10, 2023 11:28 pm
It is if they are no faster than the cheaper, single make, non-hybrid F2 cars.
Which is a concern that the 2014-2016 F1 cars had, which lead to the current "monstrosities", as Astro85 calls them.
The 2014-2016 F1 cars were slower in corners than the cars that proceeded them, but they were also a bit faster in a straight line.
vorticism
323
Speaking of car length.
𓄀
mzso
mzso
66
wuzak wrote:
Mon Sep 11, 2023 1:20 am
You can always make F2 even slower.
Or run F1 on F2 regulations. :) Which has happened before.
mzso
mzso
66
vorticism wrote:
Wed Sep 13, 2023 12:43 am
Yep. I don't think all of them are representative, on the McLaren/RB image the difference seems too little, for example.
Also these ones:
(At least the first is from this forum.)
One can dream, but I don't think the cars will get noticeably shorter. This is the FIA we're talking about. Everything takes years, and even then it's compromised or a complete failure.
The beneficial effect of the oh-so-big 2022 changes were already largely neutralized last year, yet they plan on acting on it for 2025. After which everything is trashed. There's like 99% chance the teams will successfully lobby for the changes to be skipped by then, because of the brand new formula looming. Which in turn probably be delayed a year, as always... So we will have another three years of centipede racing.
vorticism
323
It has always been that way, even prior to aero dependency. Constant overturn of race positions has never been seen in F1 and is rarely seen in motorsport aside from a few examples like certain eras of stock/touring cars and maybe two wheelers. Yet the meme still gets pushed. In fact in the early days no one could watch 90% of the racing because there were no cameras nor displays to allow this. The point then as now is still: lap faster than the competitor. Not spend x seconds per lap within two car lengths of competitor.
I don't mind long cars, I'm more concerned about heavy cars due to the ongoing institutional mission creep.
𓄀
