2026 F1 Cars - General Thread
wuzak
wuzak
532
Re: 2026 F1 Cars - General Thread
FW17 wrote:
23 Jan 2024, 11:05
F1 should have kept the battery pack out of the Power Unit. Customer teams should have been allowed to make there own custom packs with other than OEM partners. Just like teams could use different fuels and lubricants but with same engine, battery packs also could have been a cheaper option for teams to collaborate with other suppliers than buying from OEM partner.
Merc > Merc ICE > Petronas fuel > Merc A123 battery pack
Williams > Merc ICE > Total fuel > LG battery pack
Mclaren > Merc ICE > BASF fuel > Panasonic battery pack
I think you'll find they all use the same fuel.
FW17 wrote:
23 Jan 2024, 10:31
Formula E battery pack weighs 284 kgs for 47 kw which includes a structural casing, internal BMS etc. This is 0.165kwh/kg
2.5kwh ~ 9mj ~ could be about 15 kg
There must be some reason why the pack weight allowance in F1 is so high. some of the reasons I can think off is ....
>the inverter (CE) could be part of the same pack, but not sure how they can be changed separately
>cooling requirement much higher as all the cells are power optimized meant for quick charge and discharge while the Formula E battery pack has separate modules for 47kwh of energy optimized cells and a small pack of power optimized cells for the regen braking
As wuzak replied, there are now slightly more items defined within ES Main Enclosure (ESME) so it's definitely not just cells. However, the rules will still allow for only 4MJ difference in max and min SOC. So to use the full 9MJ available to harvest and use over a lap, you'll have at least 2 charge/discharge cycles over a lap. Basically, you need the batteries to run under very high electrical load and thermal stress over the entire race. The only way I can see this happening is if you have a lot of cells, but run them between 40-70% SOC all the time, so well within the 30-80% span for fast charging.
FW17 wrote:
23 Jan 2024, 11:05
I'd love to see this one day and I think it will happen. Right now, I think all teams are happy to buy the PU as a whole, it's not like you have loads of experts in high performance motorsport battery pack development and optimal utilisation. I only see McLaren as capable of doing it right now, but lets not forget that there will be very few customer teams in 2026:
Works teams - Red Bull, Mercedes, Ferrari, Aston Martin Honda, Alpine, Audi and Andretti (hopefully)
Customers - McLaren, Williams, RB (more like sister works team though) and Haas
So who knows, maybe this becomes a topic at one point.
Henk_v
Henk_v
89
I rhink it is unfair to calculate with EV power densities. An F1 car is able to discharge the entire pack in 20 seconds and is in allmost continuous duty cycle for over an hour. You'll find that is about a 2 orders of magnitude higher battery strain than an EV battery.
A Tesla in "ludicrous" mode needs about 15 minutes to condition its batteries and you get 1 go. And even then, that is about 10 times less strain than an F1 battery endures.
TeamKoolGreen
TeamKoolGreen
Alarming findings in simulator running of a 2026 car.
https://www.motorsport.com/f1/news/f1s- ... /10596682/
According to sources, when the rear wing was in its most low-drag configuration and the engine was at full power, the car was almost undriveable – with multiple examples of drivers spinning on straights under acceleration or being unable to take the smallest of curves without the rear stepping out.
This was triggered by a shift in aero balance that was estimated to be three times as much as is currently experienced when DRS is open.
One insider even suggested that the only way to prevent the cars spinning was to drive so conservatively that the lap times ended up being slower than current Formula 2 machinery.
DChemTech
DChemTech
45
Re: Alarming findings in simulator running of a 2026 car.
Well, at least we no longer have to deal with people complaining the cars are too easy to drive.
TeamKoolGreen
TeamKoolGreen
We are going to have overly complicated and dangerous Frankenstein cars because some corporate fat cats sitting around board rooms think 50/50 electric/ice sounds good. This is insane.
DChemTech
DChemTech
45
Ehm, in the basis the problem is the active aero, not the engine. Don't project your personal vendetta against hybrid on an aero issue.
Cs98
Cs98
:lol: =D> It was obvious from the moment these engine regulations were announced, the cars are underpowered and the only way to try and make up for it is through ridiculous compromises on the aero. 2026 will be slow, dead slow. If only there was a team that brought these concerns up... Oh wait, there was.
TeamKoolGreen
TeamKoolGreen
DChemTech wrote:
09 Apr 2024, 17:39
'Em no. The basis of the problem is 50% electric
DChemTech wrote:
09 Apr 2024, 17:39
The reason for the addition of "Active aero" is because of the PUs whose performance potential has been gutted by the regulation change (no MGU-H and 50% electric). It's quite a simple matter of energy conservation. The ICE has been neutered (500hp) and the "50% electric" comes entirely from the ICE.
#ReleasetheADUO
DChemTech
DChemTech
45
TeamKoolGreen wrote:
09 Apr 2024, 17:48
DChemTech wrote:
09 Apr 2024, 17:39
Not at all. You could run a 50% electric car very well without active aero. You may not like what it does, but that doesn't mean it can't be done.
TeamKoolGreen
TeamKoolGreen
Tommo F1 has a video already
DChemTech wrote:
09 Apr 2024, 17:51
09 Apr 2024, 17:48
DChemTech wrote:
09 Apr 2024, 17:39
That's the sole reason for F1 adding active aero. They do not like what it does without active aero.
50% electric can be done quite trivially. It can be done tomorrow. Cap the ICE output to 120kw by fuel flow and it could be done in time for China next week. You will not like what it does for racing :lol:
#ReleasetheADUO
DChemTech
DChemTech
45
09 Apr 2024, 17:51
DChemTech wrote:
09 Apr 2024, 17:39
That could well be, but that still does not mean that the engine is causing the issue. It's a choice to go for active aero, and to first explore this specific active option. Other choices can be made.
DChemTech wrote:
09 Apr 2024, 17:54
09 Apr 2024, 17:51
DChemTech wrote:
09 Apr 2024, 17:39
I understand your point. It's a chicken and the egg argument. F1 cars are very draggy because to have downforce is to have drag. One could point to the reliance on aerodynamics as the reason for the problem. This is also true.
However, I think people have a vision of F1 being a sport with high cornering speeds and aerodynamics are a fundamental part of that. While you could imagine a sport with no aerodynamics, that's not what F1 has been for some decades so people naturally tend to see the PU regs not being good enough as opposed to F1 cars having too much aero.
#ReleasetheADUO
