RB20 speculation
Re: RB20 speculation
MtthsMlw wrote:
13 Feb 2024, 22:32
It reminds me of the intakes of the Concorde, albeit more roundish
#REPEALtheADUO
F1Krof
96
If the inlet is to the likes of W14, at least we know that Mercedes was doing something right. Also looking at the shoulder paths on the above the halo which seem to be going along the lines of what Mercedes did last year.
Wroom wroom
continuum16
52
Xyz22 wrote:
13 Feb 2024, 22:22
Elliott redeemed :mrgreen: :mrgreen:
If the RB20 is successful, that is 8)
- Mark Twain
Apexseal157
you can see the nose is attached to the mainplane now with a long nose, potentially similar to the f1-75, the outwashing crese on the top of the pod is gone, and it may be a trick of lighting but it almost looks like there are waterslides now? https://postimg.cc/V5sjvbsY
Since we are speculating:
A:
B:
#REPEALtheADUO
Cs98
Cs98
13 Feb 2024, 22:42
A:
https://i.postimg.cc/htZZTKdD/image.png
B:
https://i.postimg.cc/GpYPtRPS/image.png
Both those would be visible on this pic, no? Unless you go with B and make it much thinner.
continuum16
52
We desperately need at least one HD pic because from what I'm seeing the bodywork is looking surprisingly similar to the W14. Nose connected to the front wing mainplane? Overbite? Sculpted cannon? Small waterslides? I would find it so unbelievably funny if all features were there on the RB and NOT on the W15, just from an ironic point of view. The floor and suspension will probably be quite different between the two regardless.
- Mark Twain
13 Feb 2024, 22:42
A:
B:
C:
Cs98 wrote:
13 Feb 2024, 22:45
13 Feb 2024, 22:42
A:
B:
https://i.imgur.com/qw2jD9Z.png
True. This angle rules those out. It is the tiniest of inlets.
#REPEALtheADUO
Cs98
Cs98
continuum16 wrote:
13 Feb 2024, 22:46
Wouldn't it just be the cherry on top for Merc to have moved the SIS down to a normal position and then the RB20 comes in looking like W14, winning.
Cs98
Cs98
Blackout wrote:
13 Feb 2024, 22:47
13 Feb 2024, 22:42
A:
B:
C:
https://i.imgur.com/XN0DthO.png
X-ray on Checo? Damn.
PinkFloydPulse
13 Feb 2024, 22:08
Last year it was noted that RB appeared to shrink the roll hoop inlet. This year it seems to have grown again?
https://i.postimg.cc/Y2Y8X1Jm/image.png
Can someone tell me that I am crazy and seeing things...
I highlighted with red on the nose...
You can see the spray on the right side of the wing THROUGH the nose... Almost like it has a double nose? First black part, then the yellow on top of it... Like we had those hideous penis noses from years ago...
Team Fernando!
marcel171281
marcel171281
31
Neither A, nor B. There is nothing but shadow under there.
PinkFloydPulse wrote:
13 Feb 2024, 22:49
13 Feb 2024, 22:08
https://i.imgur.com/xZJenDT.png
Think what you're thinking is "spray" is just reflection from the shiny surface treated carbon
Have the drivers said anything?
#REPEALtheADUO
